AE86 factory rotor diameters.
Postby Stealer Of Souls » Sat Oct 23, 2004 9:30 pm
Hey... need to know what the factory rotor diameters are for AE86
Early model, most common variety.
'86 AE85.5 Levin
Stealer Of Souls
Postby fangsport » Sun Oct 24, 2004 8:54 am
brake rotors? front or rear?
i can measure some rears if you want.
i'd be interested to know what the minimum thickness of rear rotors is as no books the brake shop has , have a listing for them.
fangsport
Re: AE86 factory rotor diameters.
Postby tatsumaki » Sun Oct 24, 2004 2:24 pm
Stealer Of Souls wrote:Hey... need to know what the factory rotor diameters are for AE86
Pretty sure they're the solid 234mm units on the front. 12.5mm thick. Minimum thickness of 11.5mm before you need to replace. Not sure about the rears sorry.
Cheers,
Paul. ;)
tatsumaki
Postby spencer » Tue Oct 26, 2004 9:14 am
Cheers,
Paul. ;)
all ae86's have vented fronts(every one I have seen) I have brand new fronts and rears and will measure.
ms63 crown
spencer
Postby Stealer Of Souls » Tue Oct 26, 2004 2:03 pm
Okay, I was told that the fronts are 234mm vented, rears are 242mm solid. But they weren't willing to bet on it.
I'm just keen to check out what mine should be...
'86 AE85.5 Levin
Stealer Of Souls
Postby spencer » Wed Oct 27, 2004 11:26 am
Stealer Of Souls wrote:Okay, I was told that the fronts are 234mm vented, rears are 242mm solid. But they weren't willing to bet on it.
there is no way the rears are bigger than the fronts they are tiny. fronts are definately vented on all 86's and solid on rears. Like I said i will measure brand new ones
ms63 crown
spencer
Postby Stealer Of Souls » Thu Oct 28, 2004 11:03 am
Cheers ke70...
I did a rough measure up of mine (using ruler and my eye), and I think that my rears are bigger (or at least same size) as my fronts... But it was a budget, rule by the eye measure.
'86 AE85.5 Levin
Stealer Of Souls
Postby JT » Fri Oct 29, 2004 2:37 pm
ke70wagon20v wrote:there is no way the rears are bigger than the fronts they are tiny. fronts are definately vented on all 86's and solid on rears. Like I said i will measure brand new ones
Pretty sure it's the other way round, rears are definately bigger than the front, I too will measure.
JT
Postby Mr Revhead » Fri Oct 29, 2004 3:23 pm
well i cant help with measurements but i can tell you the rotor part number is the same for both early and late
Postby JT » Fri Oct 29, 2004 4:08 pm
Standard front disc thickness is 18.0mm, minimum thickness is 17.0mm
Standard rear disc thickness is 10.0mm, minimum thickness is 9.0mm
This is according to the Toyota AE86 Workshop manual.
I'll measure the diameters when I get home.
JT
Postby nzae86 » Fri Oct 29, 2004 4:47 pm
The standard front dia is 235mm
The standard rear dia is 230mm
Your addiction to motorsport can only be cured by poverty!
nzae86
Postby Stealer Of Souls » Fri Oct 29, 2004 7:33 pm
Okay... So was there a rear set of brakes that were bigger? I'm guessing that there was or I wouldn't have gotten given 242mm as the size of the rears...
'86 AE85.5 Levin
Stealer Of Souls
Postby Mr Revhead » Sat Oct 30, 2004 9:42 am
not as far as i can see. there is only one part number for rear discs through out the entire model range/production run
where did you get your info from?
Postby Stealer Of Souls » Mon Nov 01, 2004 6:42 pm
Huh... wonder where the other numbers come from...
Anyone else done the measurements yet?
'86 AE85.5 Levin
Stealer Of Souls
Postby spencer » Mon Nov 01, 2004 6:56 pm
nzae86 wrote:The standard front dia is 235mm
this is what they should be measured my brand new ones and they are the same. if your rears are larger there are a few other t-series equiped cars that had larger rears maybe a swap has been done on your car
ms63 crown
spencer
Postby Stealer Of Souls » Tue Nov 02, 2004 11:42 am
Haven't measured mine yet... the info came from RaceBrakes surprisingly enough...
Steve at RaceBrakes said that according to his book the rears are 242mm... So that's what he quoted me for...
I just wanted to check for future reference, I'm not even planning on touching the rears at the moment, the rotors are only a couple of years (and about 11000km) old...
Cheers all...
'86 AE85.5 Levin
Stealer Of Souls
Users browsing this forum: No registered users and 29 guests
