Stealer Of Souls wrote:Hey... need to know what the factory rotor diameters are for AE86
Early model, most common variety.
tatsumaki wrote:Stealer Of Souls wrote:Hey... need to know what the factory rotor diameters are for AE86
Pretty sure they're the solid 234mm units on the front. 12.5mm thick. Minimum thickness of 11.5mm before you need to replace. Not sure about the rears sorry.
Cheers,
Paul.
Stealer Of Souls wrote:Okay, I was told that the fronts are 234mm vented, rears are 242mm solid. But they weren't willing to bet on it.
I'm just keen to check out what mine should be...
ke70wagon20v wrote:there is no way the rears are bigger than the fronts they are tiny. fronts are definately vented on all 86's and solid on rears. Like I said i will measure brand new ones
nzae86 wrote:The standard front dia is 235mm
The standard rear dia is 230mm
