4age questions
Postby nzae86 » Sun Nov 21, 2004 9:33 pm
never mind that, i see you are going with the redtop small port, they are afm
I am yet to see an AFM small port , the 3 that i have are MAP .
Your addiction to motorsport can only be cured by poverty!
nzae86
Postby RedMist » Sun Nov 21, 2004 9:44 pm
Camb01, where did you get your information? The ZE crank isn't forged and in all the series of 4age's there are only two cranks. ZE, redtop and 20 valve cranks are identical.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby mr_monkey » Sun Nov 21, 2004 11:25 pm
"my mates 4age blue to starlet ran realy well being high compression engine and turbo was running 16psi didnt go for long and went through 6 engines lol but what do you expect at 16psi "
Think he would have taken a hint after 5 engines? :?
mr_monkey
Postby Drifter4ag » Mon Nov 22, 2004 6:53 am
that fellas engines were sweet .. but no fuel is bad for bluetops if you are running that kind of boost .. they would also be slow without fuel
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
JZX91 MARK II CHASER
Drifter4ag
Postby TRDWGN » Mon Nov 22, 2004 9:41 pm
CAMB01 wrote:Well Redmist if you can show me the steel casting marks on a ZE or 20v crankshaft i might believe you, if you look at the crank it has a wide raised die mark which indicates a forged crank.
I have a 20v crank which is forged steel.
:roll: refers back to Mr Revhead's investigation into Toyota's Parts computer where all cranks have the exact same part number....... I would stand by this means of identification as there is the biggest chance of accuracy, if there is one thing i do not doubt it is Mr Revhead and his toyota parts database!!! lets face it no self- respecting manufacturer would have differently manufactured parts under the same part number, this would not be good logistics
TRDWGN
Postby kingcorolla » Mon Nov 22, 2004 9:52 pm
and bluetop had a seperate crank, with smaller big end journals (40mm)
1983 Carina AA63 4age
kingcorolla
Postby vvega » Mon Nov 22, 2004 9:54 pm
im not saying hes right
but you have a lot to lern with toyota
there logistest s are crappy :D
been there done that
v
vvega
Postby badidas » Wed Nov 24, 2004 10:54 pm
yeah :roll: shit im a clown i just remebered that you car being a rwd will not shed any parts i can use realy
what turbo are you using? ive got a td04 off a gsr vr4 i/c
what psi should i be running could i use the standard actuator running 10psi or will i need an external
sorry for picking your brains but i only got about 3k max to spend including buing a new engine to replace the one that i just punched a rod through the block 8O
any info would help
cheers mate
1989 mazda bongo aka [BNGBUS]
badidas
