t28 question
t28 question
Postby moo^^ » Wed Dec 01, 2004 9:35 am
what are the stats for a t28 off a GTIR ?
what effect does dual ball bearing have ?
how is it different to a t28 off a S15 ?
moo^^
Postby Rollux » Wed Dec 01, 2004 12:53 pm
S15 T28 is basically a GT28R, with slightly modified exhaust wheel, which is a dual ball bearing. Dual ball bearing will spool up about 40% quicker than an equivelent bushed T28, which is what the GTiR one is. Downside is that if the bearing dies, it's a new core or turbo, whereas bushed ones can be easily rebuilt. I think the GTiR T28 has the largest compressor cover available for a T28(from garrett), but I could be wrong on that.
Should both bolt onto an SR20DET manifold, but you may need to alter water & oil lines
2002 Allex RS180 6 Speed
Racing a Honda is like competing in the Special Olympics. Even if you win, you are still a Retard.
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Oversteer is when the Passenger is scared. Understeer is when the Driver is scared
Rollux
Users browsing this forum: No registered users and 22 guests
