Getting my W/A off, Urgently!
Postby Audi » Sun Dec 05, 2004 2:36 pm
Its actually bloddy hard to get at the dizzy its self so I may need to take it in to Toyota to get that fixed, of course its stuck in my garage so that may be a problem.
Dig a hole for the next man and you'll fall in.
Audi
Postby GT4 20 » Sun Dec 05, 2004 5:06 pm
I can't believ that you didn't check the plugs at the same time 8O No guarantee that it's causing the problem, but if a couple of the leads were shagged, then there is a high possibility the corresponding plugs could be fouled quite badly.
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby Audi » Sun Dec 05, 2004 7:46 pm
Couldn't find a spark plug removal tool. Lame excuse I know. I've checked them now, I couldn't get the 2 and 3 out no matter how hard I tried, bent the metal bar trying. But 1 and 4 seem to be firing perfectly so I am still at a loss as to the problem.
Audi
Postby GT4 20 » Sun Dec 05, 2004 9:49 pm
Hmmmm, wonder if the plugs have overheated to such an extend that they've 'welded' themselves into the cylinder head thread? Obviously there is no way that plugs should be in that tight. I would be extremely suspicious that this could be a possible cause of your problems perhaps?
Gary
GT4 20
Postby Audi » Mon Dec 06, 2004 11:26 am
It would be unusual that 2 and 3 are having problems when 1 and 4 are not though.
Audi
Postby Dell'Orto » Mon Dec 06, 2004 3:24 pm
Hmm, dunno...I've heard that the number 3 piston can lean out due to the design of the inlet manifold.
Maybe you're a gumby and were tightening them? :P
Postby Audi » Mon Dec 06, 2004 4:02 pm
Not likely, I don't do stupid things! 8) Nah I have no idea why they are so tight but its pissing me off to no end. Looks like I'm gonna have to call in a mechanic.
Audi
Postby celica_tommo » Mon Dec 06, 2004 5:17 pm
If you're just using one of those one-piece spark plug removal tools it might be an idea to borrow someones ratchet or powerbar and a sparkplug socket and extension
celica_tommo
Postby GT4 20 » Mon Dec 06, 2004 7:43 pm
Try also putting some easing oil down into the plug holes and leave overnight. The oil can then penetrate down the therads and potentaily make it easier to remove them.
Gary
GT4 20
Users browsing this forum: No registered users and 38 guests
