levin silvertop redline?
Postby dubious » Sat Dec 18, 2004 12:10 pm
hey
just wondering what the redline is for a 1993 levin silvertop?
dubious
Postby CozmoNz » Sat Dec 18, 2004 1:27 pm
redline begin or revlimit?
redline at 7500, (where it begins), ends @ 9 i think (on the guage).
revlimit is around between 7600-8000, but i swear ive had tony's up to 8,000.. or mayb his guage is funny, engine was screaming its little lungs out though ^_^.l
Rayne For President!
CozmoNz
Postby thornz » Sat Dec 18, 2004 1:30 pm
on my trueno it starts at 7600, solid at 8000, and will rev to about 8400.
thornz
Postby AceSniper » Sat Dec 18, 2004 2:12 pm
redline is ment to be 7400rpm, facelift rev limit is at 8500rpm, pre-facelift is 8200rpm I think.
mine revs to 9k ;)
*edited what was I thinking :roll: :roll: *
AceSniper
Postby minijrocks » Sat Dec 18, 2004 2:47 pm
mine goes quite happy to 8000, the red bit starts at 7500 with the line, then fully red at 8000+ , i havent taken it to valve bounce yet, and i dont really intend to unles someone wants to fix it for free if something pops
minijrocks
Postby CozmoNz » Sat Dec 18, 2004 2:53 pm
it wont valve bounce, only under uncontrollable cercimstances does it do that.
eg a car that redlines @ 6, but is revved to 8, where the springs cant handle it.
your ecu will cut you long before you manage to *bounce*
CozmoNz
Postby minijrocks » Sat Dec 18, 2004 3:45 pm
so what happens when it rev cuts? does it damage the engine? :oops:
minijrocks
Postby Dodgy Guy » Sat Dec 18, 2004 5:52 pm
ive had my silver top up to 8400. shes sounds pretty nasty at that level and things move fast internally as well!
Dodgy Guy
Postby the fallen303 » Mon Dec 20, 2004 11:57 am
if it cut's the fuel, you'd run lean, don't think thats good....
true house of JZ
Stay true to the origin
the fallen303
Postby pc » Mon Dec 20, 2004 12:19 pm
How do you change the rev limiter fom say 7500 to 8000? Is there something that can be modified in the factory computer?
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Disco » Wed Dec 22, 2004 1:44 pm
It cuts injector so yes it will run lean, this is why it's not a good thing to bounce off the limiter...
I understand that older cars have a rev limiter by way of a spring with a weight on it that is inside the dizzy - when the centrifugal force of the dizzy spinning round gets to a certain point then it will cause the spring to stretch enough stopping the spark from the rotor... (haven't had it explained properly to me and have never actually seen one so that could be slightly wrong but sounds logical) they aren't common these days as far as i know.
For the record, my facelift silvertop used to hit limiter around 8500
it's only claimed to be 8000 tho so it could just be the fact the tacho reads only 4 times a cycle (I think) and by the time it gets up there the needle just keeps going and the engine stops....
Disco
Postby 4ageman » Thu Dec 23, 2004 2:49 am
Na when you hit the limiter it cut's the spark. Ever looked behind your car when you have hit the cut and seen the puff's of black smoke come out if it was fuel it was cutting off there would be no smoke
4ageman
