anyone know where i can get one cheap in the auckland region? need it pretty much tomorrow
CozmoNz wrote:You cant tighten a bearing, you replace it.
10k 20v wrote:replacing the bearing is all good but they often wear out the bearing flange, and thats a bugger to get, replacing the bearing without checking the flange is a waste of time
they can be tightened if the cv is loose and the play usually goes away.. but the cv becomes loose (if tightned properly before hand of course) because of wear.
tightneing it to get rid of they play will do for your warrent in the meantime if it dosen't become rough afterwards
Users browsing this forum: No registered users and 27 guests
