Caldina's Throttle Position Sensor plug: need help
Postby Wolf_Tm250 » Sun Dec 26, 2004 12:26 am
Hello,
I mounted Caldina's TB on my ST205, and now I have to remove my 4-pins TPS plug, leave away IDL pin, and connect the 3 remaining wires to the Caldina's 3-pins TPS sensor:
could anyone tell me the correct position of the 3 wires from the upside ?
Thank you !
Wolf_Tm250
Wolf_Tm250
Postby Wolf_Tm250 » Tue Dec 28, 2004 9:30 pm
matt dunn wrote:From the top or bottom, depends on which way it's mounted.
Anyway, most are
brown = earth
next = sw
next = signal
next = 5v feed
Matt
Hi Matt !
I have the wiring diagram of my 4 pins ST205 TPS plug ( E2 - IDL - VTA - VC ), but unfortunately I don't know the position of E2 - VTA - VC wires on the 3 pins Caldina's TPS, so I can't connect my wires.
So what I need is the 3 pins wiring diagram of the Caldina's Throttle position sensor, the diagram you can find on the repair manual.
Thank you, bye
Wolf_Tm250
Wolf_Tm250
