i/c fan for GT-Four
i/c fan for GT-Four
Postby _will_ » Tue Jan 04, 2005 6:07 pm
Does anyone have a recomendation on what sort of fan to put on top of a St185 GT-Four's i/c?
The heat soak i was getting today was just pissing me off!!! :evil:
I know its a common mod, but just don't know what fan will be best.
Thanks :D
_will_
Postby Lunchie » Tue Jan 04, 2005 6:12 pm
theres a couple guys selling 12inch ic fans on trade me that seem to suit the application....
this guys has a pretty good explanation of how to do it
http://member.newsguy.com/~gtfour/ICfan.htm
"The air is heavy with antisipation as cozmo revs, drops the clutch and...... stalls with the hand brake on"........ "cozmo's hand brake one, cozmo 0"
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1201 <----Click to see real POWER :P
Lunchie
Re: i/c fan for GT-Four
Postby Stinger » Tue Jan 04, 2005 6:37 pm
_will_ wrote:Does anyone have a recomendation on what sort of fan to put on top of a St185 GT-Four's i/c?
Thanks :D
I was thinking of tring this too on my gt-four. If you do the mod let us know how it goes :D
1991 ST185 GT-Four RC
Stinger
Postby Dr-X » Tue Jan 04, 2005 6:39 pm
Do you think this would significantly affect the performance of the cooler while moving?
Dr-X
Postby Lunchie » Tue Jan 04, 2005 6:49 pm
id say if it was a decent fan then it would help heaps because the car may be moving quickly but the air flow into the engine bay could still be stuff all at 100kms since the bonnet scoop isnt exactly huge...
Lunchie
Postby _will_ » Tue Jan 04, 2005 6:50 pm
Not massively much while moving no. Well not at higher speeds anyway.
Its good for driving around town at slowish speeds (30-40kph or less) so i hear.
Today was really bad cos of the heat as well. My intercooler temp was 15 degrees hotter than yesterday doing the same driving!
Not good for air intake temps, and if the weather stays this way it won't improve.
Might as well have an interheater! :roll:
_will_
Postby Lunchie » Tue Jan 04, 2005 6:59 pm
at most it will only set u back like 100 bucks at it should work to an extent and who knows maybe it will save ur ass one sunny day......
Lunchie
Postby Stinger » Tue Jan 04, 2005 7:08 pm
Theres a few on trademe. I might try one out :D
Stinger
Postby _will_ » Tue Jan 04, 2005 7:23 pm
Not if i get there first!! :twisted:
_will_
Postby DeeCee » Tue Jan 04, 2005 7:55 pm
nice link - and nice site for mods - i think i'll be lifting the whole site and archiving it!!
GT Four Adovansu
DeeCee
Postby Malcolm » Tue Jan 04, 2005 8:01 pm
most important factor with the fan is the thickness. There isn't a lot of room and too thicker fan and you wont be able to close the bonnet. I know some people use Davies Craig fans, which need a small amount of trimming or SPAL ones work with no mods but I'm not sure if there is a supplier in NZ.
Postby Stinger » Tue Jan 04, 2005 8:10 pm
The guy on trademe says the fans are about 6.5cm thick. I might just do some quick measurments and see if it will fit
Stinger
Postby _will_ » Tue Jan 04, 2005 8:31 pm
What about width tho? Will a 30cm fan fit over the i/c?
Im not near my car to measure *groan*
_will_
Postby Stinger » Tue Jan 04, 2005 9:30 pm
ill do some proper measurments in the morning when i can see what im doing :D
Stinger
Postby Twolitre » Tue Jan 04, 2005 9:36 pm
Whatever you do make sure you buy a push fan, the most common size for an ST185 is 9"
twosrus.com sell them on there site so get a few ideas off that site and shop around for a better price, or just bight the bullet and buy it off them, I've bought stuff off them in the past and the service is excellent.
Twolitre
GT4 I/C
Postby Brrrrrrm » Sat Jan 08, 2005 9:07 am
Or you could install a water to air I/C from a RC. Conveniently I have the entire setup for sale -yours for $550!!
Brrrrrrm
Re: GT4 I/C
Postby Stinger » Sun Jan 09, 2005 5:02 pm
Brrrrrrm wrote:Or you could install a water to air I/C from a RC. Conveniently I have the entire setup for sale -yours for $550!!
damn thats temping, got any pics of all the gear? i might be keen, but im not sure how to do the installation etc of it.. I would also have to buy an RC bonnet too right?
thanks
:D
Stinger
Re: GT4 I/C
Postby celica_tommo » Sun Jan 09, 2005 6:48 pm
thanks
:D
Depends on the position or the water to air as compared to air to air... i assume they're in the same position... also I would assume that having the bonnet scoop rather than vent would not be too bad considering an st-165 has not vent or scoop for its water to air
celica_tommo
Postby Malcolm » Sun Jan 09, 2005 10:11 pm
the rc w/a fits fine with normal gtfour bonnet + bumper, and $550 is a very good price for a complete set up
Postby Stinger » Fri Jan 28, 2005 4:27 pm
Thanks Brrrrrrm for the awesome deal! I owe you one :D
Looks like i will be going thru with this RC intercooler swap this weekend hopefully :P
Stinger
