Bluetop Check Engine Light
Postby ee904age » Wed Jan 12, 2005 6:19 pm
Does the Check pin on a bluetop ecu give 12v or switched earth?
Im having a few issues with my engine (transplant) and want to hook up a check light.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby kingcorolla » Wed Jan 12, 2005 7:52 pm
im pretty sure it switches earth.
your doing a transplant, do you have a speed sensor hooked up? if not, your check light will constantly play up.
1983 Carina AA63 4age
kingcorolla
Postby ee904age » Wed Jan 12, 2005 8:00 pm
Did transplant over a year ago, a few probs have come along.
I dont have a speed sensor but doesnt that just make the code for it show up each time? It will still show others wont it??
90 SW20 N/A - Sold
ee904age
Postby kingcorolla » Wed Jan 12, 2005 10:11 pm
i read this somewhere
If you want to run a 'check engine' warning light (which is also the means of displaying diagnostic codes) then you must run a speed sensor, which is normally part of the speedometer. If you do not run this sensor you will get an intermittent trouble warning on the check engine light, however the engine performance is not affected.
kingcorolla
Postby matt dunn » Wed Jan 12, 2005 10:50 pm
If you dont have a speed sensor the light will just come on at times when you are driving.
It will still show all the other codes.
the ecu earhts out the light.
Matt
