Does the Check pin on a bluetop ecu give 12v or switched earth?
Im having a few issues with my engine (transplant) and want to hook up a check light.
If you want to run a 'check engine' warning light (which is also the means of displaying diagnostic codes) then you must run a speed sensor, which is normally part of the speedometer. If you do not run this sensor you will get an intermittent trouble warning on the check engine light, however the engine performance is not affected.
Users browsing this forum: Google [Bot] and 40 guests
