Tacho
boost
oil press
water temp
Are there any posts already about as I cant seen to find then with detailed info .
Bazda wrote:the oil gauge in the car is electronic....
Ebola_One wrote:Bazda wrote:the oil gauge in the car is electronic....
Yeah, so there'll be a dirty great electronic sender (if it's pressure) or (this is one methid I've hear of) you can tap a new hole into the sump for a tempetature probe (if it's a temp gauge)
Bazda wrote:then u will have to take the sump off.
easier to go buy an adapter for your oil filter and both oil temp and pressure can screw into it.
Users browsing this forum: No registered users and 36 guests
