Tacho
boost
oil press
water temp
Are there any posts already about as I cant seen to find then with detailed info .
Bazda wrote:the oil gauge in the car is electronic....
Ebola_One wrote:Bazda wrote:the oil gauge in the car is electronic....
Yeah, so there'll be a dirty great electronic sender (if it's pressure) or (this is one methid I've hear of) you can tap a new hole into the sump for a tempetature probe (if it's a temp gauge)
Bazda wrote:then u will have to take the sump off.
easier to go buy an adapter for your oil filter and both oil temp and pressure can screw into it.
