RX7 Intercooler on SW20 MR2
Postby mister_two » Mon Jan 17, 2005 11:08 pm
Saw a few MR2 doin this mod , is it worth it?
and what sorta series RX7 intercooler is best?
cheers for the input guys :D
mister_two
Postby Dell'Orto » Tue Jan 18, 2005 12:17 am
Series 5 if you can find them, but series 4 ones do well ;)
Postby MrBob » Tue Jan 18, 2005 1:03 pm
I have a couple if you want to buy them :D
MrBob
Postby Pies » Tue Jan 18, 2005 9:33 pm
mrbob: prices? are they top mount or side? or boot?
Current Rides:
Pies
Postby MrBob » Wed Jan 19, 2005 10:02 am
pies_the_pirate wrote:mrbob: prices? are they top mount or side? or boot?
hey, ones off a s4 and ones off an s5 (same cores, slightly different tanks). Neither have been fitted to another car before. I think it would fit well in the standard location on the MR2 tho.
$100 each
MrBob
Postby Pies » Wed Jan 19, 2005 6:24 pm
are they much better than standard?
id be keen on the 5 if u stil have it.
Current Rides:
Pies
Postby Dell'Orto » Thu Jan 20, 2005 1:30 am
Anything is better than the stock ones :lol:
The S5 core does flow a bit better than the S4 too, but both are very efficient.
Postby fivebob » Thu Jan 20, 2005 1:38 am
Mmm, Boost wrote:Anything is better than the stock ones :lol:
Actually the stock core is quite efficient, and takes a long time to heatsoak with good recovery. However it's let down by the pressure drop. :evil:
Postby Al » Thu Jan 20, 2005 5:47 am
fivebob wrote:Actually the stock core is quite efficient, and takes a long time to heatsoak with good recovery. However it's let down by the pressure drop. :evil:
I wonder how much boost my ct20b is actually pushing at an indicated 18psi at the manifold :o
Al
Postby mister_two » Thu Jan 20, 2005 9:47 am
So would this bolt on straight using the old piping or new plumbing should be made? what u guys reckon?
mister_two
Postby Dell'Orto » Thu Jan 20, 2005 10:45 am
Nope, you need new piping, and/or new end tanks, depending on how neat you want it.
You dont know the flow figures of one by any chance do you?
Postby MrBob » Thu Jan 20, 2005 11:45 am
pies_the_pirate wrote:are they much better than standard?
yep, still have it. The efficiency is meant to be as good as, or better than a vr4 one
MrBob
Postby MrBob » Thu Jan 20, 2005 11:46 am
mister_two wrote:So would this bolt on straight using the old piping or new plumbing should be made? what u guys reckon?
will not bolt straight on. Will need to change the outlets on the tanks and make up some mounts.
MrBob
Postby Twolitre » Thu Jan 20, 2005 12:48 pm
You guys should do a search of autospeed.com
They did quite a comprehensive comparison of used japanese model intercoolers and if I recall correctly the series 4 IC is actually better than the series 5 due to the end tanks or something like that.
Twolitre
Postby TygerTung » Thu Jan 20, 2005 12:59 pm
I would have thought a water to air intercooler with the radiator front mounted would be a good idea on an MR2?
TygerTung
Postby dragonx » Thu Jan 20, 2005 1:39 pm
TygerTung wrote:I would have thought a water to air intercooler with the radiator front mounted would be a good idea on an MR2?
its cost a few more cents than an old rx7 IC
water lines, pump, W/A IC and rad and plumbing
i wouldnt waste my time going from stock to a rx7 unit,
In the Land of Dunedin
dragonx
Postby fivebob » Thu Jan 20, 2005 1:58 pm
Mmm, Boost wrote:Nope, you need new piping, and/or new end tanks, depending on how neat you want it.
No I do't have any flow figures, IIRC pressure drop was around 2.5psi at 17psi manifold pressure, but I haven't got the datalogs on this computer so I can't confirm it.
Postby Lekz » Thu Jan 20, 2005 2:26 pm
when they replace the intercooler with an rx7 can it fit to the SW20? are they planning top mount of front mount? :?
Lekz
Postby aesc » Thu Jan 20, 2005 2:54 pm
Leks wrote:when they replace the intercooler with an rx7 can it fit to the SW20? are they planning top mount of front mount?
Side vent mount 8)
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Lekz » Thu Jan 20, 2005 3:02 pm
ooo'k... lol thanks for that i guess it would b hard for an mr2 to have a front mount... :?
Lekz
Users browsing this forum: No registered users and 43 guests
