and what sorta series RX7 intercooler is best?
cheers for the input guys
pies_the_pirate wrote:mrbob: prices? are they top mount or side? or boot?
fivebob wrote:Actually the stock core is quite efficient, and takes a long time to heatsoak with good recovery. However it's let down by the pressure drop.
fivebob wrote:Actually the stock core is quite efficient, and takes a long time to heatsoak with good recovery. However it's let down by the pressure drop.![]()
pies_the_pirate wrote:are they much better than standard?
id be keen on the 5 if u stil have it.
mister_two wrote:So would this bolt on straight using the old piping or new plumbing should be made? what u guys reckon?
TygerTung wrote:I would have thought a water to air intercooler with the radiator front mounted would be a good idea on an MR2?
Mmm, Boost wrote:Nope, you need new piping, and/or new end tanks, depending on how neat you want it.fivebob wrote:Actually the stock core is quite efficient, and takes a long time to heatsoak with good recovery. However it's let down by the pressure drop.![]()
You dont know the flow figures of one by any chance do you?
