Fuel Sender - KE70
Fuel Sender - KE70
Postby solberg Fan » Tue Jan 18, 2005 8:26 pm
Hey, ive ot a problem with my fuel gauge, its doing weird and crazey things. I have pulled the fuel sender out of the tank, but need to know what the specifications are for the ohm readings. At the moment its jumping around the place as i move the float up and down and i think it should be a smooth increase and decrease (Ive never had to check one before, so if im doing it wrong, Please tell me!)If any one has a workshop manual thatd be great.
Or should I just get one from pick-a-part and try that?
Are the fuel senders the same in the starlet as what ive got?? :?
cheers for the help.
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them, you're a mile away and you have their shoes.
solberg Fan
Postby kingcorolla » Tue Jan 18, 2005 9:47 pm
these are the resistance readings you should get from the sender to earth.
(float) full position - 3 (plus or minus) 2.1 ohms
1/2 position - 32.5 (plus or minus) 4.8 ohms
empty position 110 (plus or minus) 7.7 ohms
you should check the security of the wires for the gauge curcuit also.
to test the gauge itself, disconnect the wire on the back of the gauge, (the one from the sender), and connect a wire from the terminal to earth, via a 3.4W bulb. Then turn the ignition switch on, and the bulb should light, and then start to flash after a few seconds. The gauge needle should aslo deflect. If not then its your gauge thats faulty, but chances are its the sender because they usually fail before the gauge does.
you can thank Mr Haynes for this info :wink:
1983 Carina AA63 4age
kingcorolla
Postby solberg Fan » Wed Jan 19, 2005 1:20 pm
Cheers man. Ill try it today. And thanks for the readings! :)
Team KB' Racing
1981 DX corolla
*My KE70*
solberg Fan
