Something is missing .....
Postby gordon77 » Thu Jan 20, 2005 9:58 pm
well i have a 91 ae92 fxgt. ever since i got it it sort of whistles under certian throttle positions. thinking it was air intake (producing the whistle) i took the air intake pipe off and found there was a large rip around the ribbing in the pipe. i fixed it with gaffa tape, works a treat but still whistles slightly :evil:
then i found a hole in the back of the filter housing. it has a rubber seal around it sort of like an o ring. i am thinking there is suposed to be a sensor in there of some sort... whats missing???
when the car is hot and has been running for ages the ilde drops to like 500 rpm. when you cover the hole with your finger it raises the idle slightly :?
What is RR?
gordon77
Postby CAMB01 » Thu Jan 20, 2005 10:03 pm
there should be an air temperature sensor in the airbox. Is just one part of the system to meter the fuel.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Zak » Thu Jan 20, 2005 10:04 pm
Isn't that for the air temp sensor?
If you can get a pic or two, we'll be able to help you a lot more.
Zak
Postby gordon77 » Thu Jan 20, 2005 10:07 pm
yeah i was thinking it was the air temp sensor. is this crutial to the engines running???
What is RR?
gordon77
Postby Twolitre » Fri Jan 21, 2005 1:09 am
It's not crucial but it should be in there, if there's a hole where it should be then your engine will be sucking in un-filtered air, it's prob had a pod filter on it at some stage and a previous owner has just removed it.
Is it small port non tvis 4age by the way?
Twolitre
Postby gordon77 » Fri Jan 21, 2005 2:28 pm
yup shes a small port non tvis. it doesnt look like there are any loose connectors around the area so maybe the person before me cut it right out. grrrr :evil: :evil: :evil:
What is RR?
gordon77
