Help!! AE92 4agze a/c , p/s drive belt
Postby crispy'86 » Fri Jan 21, 2005 12:19 pm
How does the power steer drivebelt adjust on these?? I'm putting normal 4age into a gtz trueno i got guy i bought it off has the gze for his conversion. I am using the bracket for the power steer, air con pump and may be missing bracket to hold the power steer pump tight. Alternator is on intake side , any ideas, any pics, links?? i need to know a.s.a.p. if i need anything
crispy'86
Postby Banga69 » Fri Jan 21, 2005 12:57 pm
well from a gtz the belts a adjust by a pulley its right above the crank pulley u need a 14" socket to adjust it.
hope that helps
anyone else??
CURRENT:
1994 Mazda Lantis
EX:
SOLD: AE101 GTZ ====>http://toyspeed.blakjak.net/profiles/profile.php?id=89
Banga69
gze
Postby crispy'86 » Sat Jan 22, 2005 1:08 pm
yeah the a/c pump tensioner is there but they run two belts, 1 for the a/c from the crank and one belt from a/c/ pump to p/s pump. I haven't seen any adjustment possible from this as i am probably missing a few brackets etc.
crispy'86
belt
Postby JasonZE » Sun Jan 23, 2005 10:34 pm
The ZE p/steer pump used a slot type bracket so you can swivel the pump till the belt is tight then lock the bolt , the slotted bracket is on the bottom of the pump if you dont have one it wont be hard to adapt an alternator one or similar to fit.
JasonZE
Real Life Mechanic
