How the....
How the....
Postby Dell'Orto » Fri Jan 28, 2005 11:58 am
hell do you get out rounded off bolts? I have one last bolt to get out before I can pull my turbo off, and some $&#$% monkey has rounded it off?
Its very easy to get at with spanners and whathave you, but Im stumped for ideas and I need to get it ot this afternoon!!!
Any help is appreciated.
oh, and if anyone from Turbo tech reads this - thanks for rounding off one of the easiest to get at bolts in the entire exhaust system :?
Postby 2LTR Rona » Fri Jan 28, 2005 12:12 pm
depending on how much room you have to play with, you could always file the hex head back onto it.....or if you have a really decent pair of vice grips you could also try that....and lastly depending on how much damage you want to or don’t want to do to the bolt you could always get a slightly smaller sized socket and force it on there with a FBH :P
good luck dude
2002 Altezza, 1974 KE25
2LTR Rona
Postby ee904age » Fri Jan 28, 2005 12:14 pm
Use an easy out, you will probably need a cobalt drill to drill through it but thats probably the best way.
Or do it 'bro styles' and file or grind the hex back to the next size smaller spanner.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Dr-X » Fri Jan 28, 2005 2:12 pm
Best way is use an easy out, but keep in mind they're not usually as easy as the name would suggest :roll: What bolt is it? You could certainly try hammering on a smaller socket, I have done this before.
Dr-X
Postby fivebob » Fri Jan 28, 2005 2:21 pm
Will a 6pt socket still fit? Might work if it's not too stuffed, but heat it up first and then squirt some WD40 or CRC on it and leave it for a while. If that doesn't work see if you can find a supplier of Mouse Milk in NZ, that will loosen it up for sure.
If the bolt is rusted in then an Easyout is likely to break and cause you more problems :( If you can get a drill onto it then the best idea is probably to drill the head off it.
Postby Dodgy Guy » Fri Jan 28, 2005 4:06 pm
If your not fussed about loosing a bolt you could try a couple of things - both which worked for me.
depending on how tight the bolt is you could try to lock tight of weld another bolt head onto it and the undo it
or
use and old screw driver and hammer and try and tap the bolt off that way
Dodgy Guy
Postby Dell'Orto » Fri Jan 28, 2005 4:09 pm
mmm, thanks guys.
For anyone who's ever taken a turbo off an MR2, its the first bolt on the "turbine elbow" hanger, it bolts on to the block so not so keen on drilling it off. Will try some of the other suggestions though.
Brad
Postby fivebob » Fri Jan 28, 2005 5:28 pm
Mmm, Boost wrote:mmm, thanks guys.
Nah you're only drilling the head off it so it won't even come near the block, then you remove the remainder with some vice grips. Can't see it being easy to get a drill in there anyway, so welding another head on the bolt is probably the best alternative. Don't forget to use a 6pt socket though, or you'll likley round that one off too :(
Postby 2fas4u » Fri Jan 28, 2005 5:57 pm
like mentioned before, it depends on where it is. you could try and get a powerful cordless drill with a decent drill bit designed for drilling through metal which is quite long and drill a hole across through the bolt head and shove a allen key through it and turn it.
2fas4u
Postby evil_si » Fri Jan 28, 2005 6:21 pm
how rounded is it? use a single hex socket, 6 side,
weld a nut on the rounded head, then just undo it,
or bash the next size down socket on, it,
personally unless its a snapped bolt etc dont bother drilling it,.
evil_si
Postby TRD Man » Fri Jan 28, 2005 7:33 pm
In the 70's they sold spanners that tightened around rounded off bolts. I've got a pair of them here.
But you can buy (or at least you could) sockets that do the same thing. Stud removers.
Or we'd use easy-outs as somebody has suggested.
I guess the solution depends on how accessable the bolt is.
Ask a mechanic at your local garage. They'll have the tool. They probably won't lend it to you. You could offer to leave a deposit.
In my day a dozen beer bought a lot of favours.
TRD Man
rounded bolt
Postby GOLDAE86 » Fri Jan 28, 2005 7:42 pm
All of that sounds to hard, just use a flank drive socket or spanner. 8)
To finish first, first you must finish
GOLDAE86
Real Life Mechanic
Postby Dell'Orto » Fri Jan 28, 2005 7:47 pm
Got one I can borrow? :D
Postby smokabitabud » Sun Jan 30, 2005 9:15 pm
smash a 1mm smaller socket on man it doesnt do shit to the socket i had to do it twice in the last day helping my m8 take out the gear box on his 3k
smokabitabud
Postby Virtual Genocide » Sun Jan 30, 2005 10:14 pm
Get yourself a set of these:
The greatest tool ever made to undo rounded bolts etc
You can sum up the entire dream world of the motoring enthusiast in four words: "dont fence me in"
My Profile <----- check it out!
Virtual Genocide
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
