Length of supercharger dipstick
Postby Voodoo » Sat Jan 29, 2005 5:38 pm
as mention in another post, i dont have a dipstick on my supercharger, just the yellow wingnut, anyway was going to just empty it and refill it with 130mls , but the sump nut sits to close to one of my engine mounts to get at (rwd conversion) so anyway just wondering if someone could measure the length of there dipstick from the top to the high or low point oil point, as ive read it is 100 mm between them, that way i stick something down there to measure for now
Voodoo
Postby evil_si » Sat Jan 29, 2005 10:22 pm
hey,
the total length of the dipstick, from the base of the washer/seal on the wing nut, to the end of the dip stick, is 123mm,
from the base of the washer to the high mark is 69mm
from the base of the wingnut to the low mark is 113mm.
hope this helps
evil_si
Postby Voodoo » Sat Jan 29, 2005 10:23 pm
cheers man!
Voodoo
Postby KinLoud » Sun Jan 30, 2005 8:43 am
Have a damn good look down the little hole to make sure that the rest of the dipstick hasn't broken off and fallen in!!!
Ken
Ham
021 408 863
Postby Voodoo » Sun Jan 30, 2005 11:19 am
yeah i was acually thinking about that, would it end up near any moving parts?
Voodoo
Postby evil_si » Sun Jan 30, 2005 8:40 pm
yes could come in to direct contact with the gears. if it was gto be caught up, it would be very messy, new s/c time infact
evil_si
Postby Voodoo » Sun Jan 30, 2005 10:16 pm
haha o dear, o well ill grab one of those pully kits off ya and make sure its really spinning when i hits :wink:
Voodoo
Postby evil_si » Sun Jan 30, 2005 10:55 pm
you can safely remove the rear cover of the blower, no special tools required apart from a normal 12mm socket or spanner
that way you can be sure
pull the cover off, there is an oring that seals it, and the gears will be visable,
evil_si
