Newwwwwbie
Newwwwwbie
Postby Willdat? » Wed Feb 09, 2005 10:15 am
2005 spells the start of a new project car...
take one Grandad owned AE85 3A-U auto for $600
Add a silvertop 20v 4AGE for $700 (with fwd gearbox which will be sold...)
And a T50 gearbox with 4A bellhousing for $250
This is going to be our first engine swap (ie not just straight replacement)
Has anyone got any advice at all?
After a bit of investigation it sounds like the distributor position is going to be a bit of a challenge...
Any experience/links would be much appreciated and i'm sure I'll get to know y'all better in the future
Willdat?
Postby Ae92typeX » Wed Feb 09, 2005 10:24 am
If you do a search the distributor issue has been discussed somewhere... someone hab built a pully or something to run it off the belt i THINK?
nice project anyway
Ae92typeX
Postby thaphatty » Wed Feb 09, 2005 5:54 pm
yep ke70wagon20v came up with a good way to relocate the dist. to the front end, if you wanna know more pm him, he might be persudaded with a little $$ :wink:
thaphatty
Postby Adamal » Wed Feb 09, 2005 6:51 pm
I'm pretty sure you also have to change the rear brakes from the drum setup to the 86 disc setup for it to get a cert!
I have the feeling there's something else as well but I can't remember..... Anyone?
Postby Willdat? » Wed Feb 09, 2005 7:32 pm
Ah yes cert....well we'll get the engine/gearbox in first before we get too worried with cert! The disc rear/LSD is obviously desirable, but at the moment we haven't found one...if anyone has one feel free to PM me
In Dunedin there is/was a DX rolla with 3sgte (and cert) but still the standard brakes...including drums obviously, as far as I'm aware as long as your car can handle a few stops from 100km/h that's enough for cert?
Willdat?
Postby Dr-X » Wed Feb 09, 2005 8:54 pm
Why would you need the rear brakes upgraded for a cert?
Dr-X
Postby NZ_AE86 » Wed Feb 09, 2005 9:48 pm
Cert requires your car to complete a certain No. of stops from, I think, 100kph, 6 stops back to back rings a bell. but either way factory AE85 brakes are up to it! Although AE86 brakes are required for any track work. :)
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby Willdat? » Thu Feb 10, 2005 10:05 am
Sweet that was what I was hoping, I haven't had much (ANY) experience with cert so it's nice to know this stuff!
I guess you might need to upgrade the rear brakes IF your car was putting on the pounds ie 2JZGTE into your KE10, along with lead sound deadening....
Willdat?
Postby ALLEN » Thu Feb 10, 2005 2:27 pm
For the conversion, check out www.club4ag.com
For the diff, try this
Trueno, Diff AE86, disc brakes, good cond, very rare $600 ono
Otago Southland Contact 03-476-2202
:D
ALLEN
Postby Chickenman » Thu Feb 10, 2005 2:38 pm
As long as you got Ventilated fronts you shouldn't need to worry about the rears for the cert. Definately suggest it though, especially for racering.
Baby Jesus
Chickenman
I Am The Walrus!
Postby deaf_rattle » Thu Feb 10, 2005 2:38 pm
i believe for the brakes, they do 0-100 then stop, 0-100 then stop and then on the third time thats the one that matters.
as long as the engine isnt significantly heavier than the standard one, you shouldnt have too many issues.
But for peace of mind, might pay to get better brake pads and fluid.
you can get decent compound put onto your drum shoes as well
Re: .
Postby pervert » Thu Feb 10, 2005 2:45 pm
Willdat? wrote:In Dunedin there is/was a DX rolla with 3sgte (and cert) but still the standard brakes...including drums obviously, as far as I'm aware as long as your car can handle a few stops from 100km/h that's enough for cert?
The one with the white stripe over the bonnet? That is long gone, the current owner (although it is/was for sale, so he may not be the owner anymore) posts on here under the name DEVILE.
pervert
Postby MattrickMotorsport » Thu Feb 10, 2005 5:04 pm
The runing the pully off the dizzy has been used many times there is apic somewhere ill try get it :lol:
MattrickMotorsport
Postby Willdat? » Thu Feb 10, 2005 7:56 pm
Cheers for that, at the next agm we'll discuss the disc rear end...t'will be good to get back to Dunedin so I can stop 'working' and start uni...and start disassembling/reassembling this project!
From a resale prospect are we better off doing this 20v conversion, or being a bit different and modding the 3A? We can get cost parts at Repco, so the 3A would basically get reconned/recammed etc. etc. or is it really the boat anchor that it has been described as ?!
Willdat?
Postby thaphatty » Thu Feb 10, 2005 9:26 pm
man, its the boat anchor from narm, i did alot to my old one, and i used to have to rev the nuts off it and it was still a way off a $300 bluetop :x
thaphatty
Postby Willdat? » Fri Feb 11, 2005 1:12 am
Something I'm more concerned about for cert (potentially) is the hole in the firewall, how can they give you cert with a hole in the firewall?!It's not like it's a small one either...well to me 250 x 300 mm is a bit on the large side...
Willdat?
Postby AJz » Fri Feb 11, 2005 2:29 am
hahahahhaha, hmmmm, that is a bit on the large side, could be interesting.
I had vtax :(
AJz
