4agte fuel economy!
4agte fuel economy!
Postby Andy from the block » Thu Feb 10, 2005 11:09 pm
I just bought a AE101 GTZ with a turbo conversion.
Its running a series 4 rx7 turbo which I was told was quite large, able to support over 330hp easy.
The car has had a engine rebuild less than 700kms ago.
But looking at how much fuel its going through Im seriously wondering
if somethings up.
It does around 230kms to 42L of 98 octane.
5.4kms a litre!!!
This is with moderate boosting and average stop and go traffic driving.
When I stand outside I can smell petrol quite strongly.. much more so than my other levin.
Is this normal for 4agte's? or for engines with recent rebuilds?
Why does the car seem to run soo rich?
Andy from the block
Postby Chickenman » Fri Feb 11, 2005 12:03 am
It may be tuned to run rich and safe... take it to a dyno and get a A/F graph.
The MR2 is doing about 6-8km's/litre. Me is only got 8-9 pounds of boost though...
Welcome to turbo powa :?
Baby Jesus
Chickenman
I Am The Walrus!
Postby Andy from the block » Fri Feb 11, 2005 12:14 am
yeah I suspect it might be tuned to run rich.
How exactly do they tune the A/F mix?
Im kinda thinking its wayy too rich/safe cuz even evos/skylines/wrxs etc with more power than Im putting out dont guzzle gas like that.
Andy from the block
Re: 4agte fuel economy!
Postby Dell'Orto » Fri Feb 11, 2005 12:18 am
Andy from the block wrote:I just bought a AE101 GTZ with a turbo conversion.
if somethings up.
5.4kms a litre!!!
A standard S4 turbo? Would have thought that would incredibly laggy on a 4AGE :?
It probably is just in a basic state of tune while the motor is being run in, once it is it'll be ready for a dyno tune, that will sort it out no end.
Postby EVLGTZ » Fri Feb 11, 2005 7:31 am
nah not standard s4 turbo, mated with skyline exhaust i'd say. Work pretty dam well actually.
Andy - thats way too much fuel mate. Considering I can get 400-450km per tank on that amount of gas running around on 1bar or more.
I doubt its 'tuned' to run that way as there is pretty limited tuning that can be done with the std ecu still in place.
might find the injector seals have given up the go or something like that?
If you wanna meet up today I can have alook 021 523371
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby evil_si » Fri Feb 11, 2005 10:49 am
it isnt a standard series 4 turbo, machined out t3 exhaust,
a for that much fuel ???, im know i use to have a lot better fuel ecomomy than that,
is it running allright? is the exhaust out lets very black?
the a/f was checked when it was dynoed running 11psi, it pretty sweet then. i never got the actual a/f print out so i cant say for sure what the ratios were.
actually, did you manage to suss out the speedo problem you posted up about? do a check with another car and recored the same distance on both odometers and make sure its the same. sounds a bit like what it did when the first speedo died.
evil_si
Postby Bazda » Fri Feb 11, 2005 4:40 pm
just boost it harder andy, stop driving off boost :lol:
Postby Andy from the block » Sat Feb 12, 2005 5:38 pm
Thanx jade and evil_si for your input.
cheers for the check up offer jade, I'l let you know if I need it. :D
yeah I still gota check the odometer to see if its accurate with another car.
I will post up a reply when Ive done that.
theres no carbon fouling on the bumper near the exahusts at all.
Andy from the block
Postby mister2 » Sat Feb 12, 2005 6:26 pm
Previous owner didn't just replace the injectors with bigger ones? Then it would run pig rich. Still running the gze computer or aftermarket??
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Postby cr1mnl » Sat Feb 12, 2005 7:49 pm
all standard - fuel gear, injectors, regulator, ecu
www.ology.co.nz
cr1mnl
Postby 1598cc » Sun Feb 13, 2005 8:34 pm
check for leaks around injectors.
mine used that much fuel as well, if not more, and always stunk of gas, untill i checked the injector seals to find they were poked.
1598cc
