is this a fuel pump?
Postby l1ttle_d3vil » Fri Feb 11, 2005 9:02 pm
probably the dumbest question yet :oops: - but found this in the box of stuff i was given with my 4age engine. i don't know exactly what it is though and neither does anyone else ive asked. is it a fuel pump - and if so, will it do to run my 4age? (bluetop)
Postby 85AW20v » Fri Feb 11, 2005 10:44 pm
Nope - I'd say a vacuum service valve - possibly to actuate TVIS or something similar.
See ya
Simon
85 MR2 20v
85AW20v
Postby vvega » Fri Feb 11, 2005 11:10 pm
air con idle up valve
it has a thubscrew on it to finetine the idleup when aircon is switched on
v
vvega
Postby matt dunn » Fri Feb 11, 2005 11:18 pm
vvega wrote:air con idle up valve
v
yes, just what i was abaout to say.
Postby vvega » Fri Feb 11, 2005 11:53 pm
I think you have to worry when without even trying you can identify solenoids off your car without even thinking about it :S
vvega
Postby l1ttle_d3vil » Sat Feb 12, 2005 9:36 am
v
cheers. seeing as ive put the 4age in a 1975 corolla i dont think i'll be needing it then lol :D
Postby pc » Mon Feb 14, 2005 8:27 am
I always wondered what my one was on the top right side of the firewall (when looking from front of car). Now that I know I should remove it, does anyone know if there is anything special to removing it or do you just bypass it with the vacuum hose and unplug it?
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby XS1V » Mon Feb 14, 2005 8:54 pm
If you still have aircon you shouldnt remove this, its important for running as it increases rpm so the engine doesnt stall when load is apllied due to the aircon pump running
XS1V
