APEXI AFC info wanted please
Postby DEVILE » Sat Feb 12, 2005 6:25 pm
I am considering buying an APEXI AFC and I was wondering if anyone has ever used one on a silvertop 20 valve?
Will this be enough to remove the air flow meter once it is installed? are they easy to install/use? reliable?
Any help appreciated.
Thanks
Steve
previous :1980 DX rolla
ae101 fxgt
GTT caldina
current: bighorn
project: ae.. fxgtt
http://toyspeed.blakjak.net/profiles/profile.php?id=830
T caldi
http://genesis-race-division.com/devile/
DEVILE
Postby Al » Sat Feb 12, 2005 7:22 pm
Its a piggy back fuel controller so it will never replace the AFM on its own.
To get any gains you will have to use a wideband a/f meter during tuning.
Al
Postby DEVILE » Sat Feb 12, 2005 7:27 pm
what is a wide band a/f meter and where wuld i get one?
ae101 fxgt
GTT caldina
current: bighorn
project: ae.. fxgtt
T caldi
DEVILE
Postby Al » Sat Feb 12, 2005 7:55 pm
Any decent tuning garage will have one with their dyno. Otherwise if you wanna do it on the street a decent wideband setup will cost around the $600 mark if not more.
Al
Postby DEVILE » Sat Feb 12, 2005 8:51 pm
its a super afc if that changes anything as well
cheers man..i'll ask around
ae101 fxgt
GTT caldina
current: bighorn
project: ae.. fxgtt
T caldi
DEVILE
Postby Al » Sat Feb 12, 2005 9:00 pm
Nah when you tune you need a wideband, makes no difference on the model of piggy back
Al
Postby Bazda » Sun Feb 13, 2005 12:12 pm
so this device can able u to put larger injectors in with the standard ecu? and larger afm?
Postby Monsterbishi » Sun Feb 13, 2005 12:29 pm
Bazda wrote:so this device can able u to put larger injectors in with the standard ecu? and larger afm?
Pretty much, but it does have it's limitations.
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
