Cam Timing
Cam Timing
Postby CAMB01 » Sun Feb 13, 2005 7:04 pm
I'm putting some Bluetop cams into my 4AGZE, What i want to is should i time them to the standard settings or if anybody has any specs where i could time them, as i have a pair of Vernier Adjustable Cam gears.
Any info would be appreciated.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby CAMB01 » Wed Feb 16, 2005 9:31 pm
bump
CAMB01
Postby atmosports » Thu Feb 17, 2005 6:00 pm
Put them in on the factory settings & turn the motor slowly over by hand toi make 100% sure they are correct & aren't gonna hit. Then put the car on a dyno & play with the cam timing, you'll probably find the inlet will stay in much the same position & you'll only need to vary the exhaust a degree or two, but best to put it on a dyno to do it.
atmosports
Postby CAMB01 » Thu Feb 17, 2005 8:53 pm
Sweet cheers man, i was planning on dyno ng it.
CAMB01
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
