NEED HELP: VVT light
Postby LEV_101 » Tue Feb 15, 2005 7:47 pm
hi everybody, just recently signed up. wondering if you guys can help me with the VVT light ( read it in this other forum in the VVT light), i can seem to get it going... also solutions? not sure if i wired it correctly... how do i even know if its working. ?
thanks ! :D
LEV_101
Postby aesc » Tue Feb 15, 2005 10:44 pm
Have a look at this champ
viewtopic.php?t=9236
EX AE101 owner
2013 Ford Focus ST
aesc
Postby B1NZ » Tue Feb 15, 2005 10:51 pm
try switching the LED around the other way, if still not work then you probably havent got the VVT activation wire from the ECU :wink:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby LEV_101 » Wed Feb 16, 2005 4:00 pm
yea ... thats what i did on what the page said to do ... but it doesnt seem to work :cry: when does vvt actually work? thanks for you guys helping me !
LEV_101
Postby TruenoBoy » Wed Feb 16, 2005 5:45 pm
have you warmed the car up before trying to see if it works? it only works once the car is a running temp.
Have another look and make sure you have the right wire.
vvt comes on when you are over 50% throtle I think ( it is also dependent on o ther things like engine temp etc) make sure your oil level is correct, it may not be activated with low oil.
TruenoBoy
Postby CozmoNz » Wed Feb 16, 2005 6:32 pm
when your temp is up to optimum... and when you have X throttle with X rpm.
Rayne For President!
CozmoNz
Postby lotstodo » Wed Feb 16, 2005 6:54 pm
This is the guide i used, easy as can be. Works sweet too.
VVT-------------------------------------------------------ECU
|-------------------------------LIGHT--------------GROUND
| ------- <=== 3-Way Switch |
1) Cut into the VVt wire in the vvt.
2) Run a Wire off that and connect it to one side of your 3-way switch
3) Run a wire from the other side off the switch to ground
4) Leave the middle one not connected to anything
5) Cut into the wire you have connected to the VVt (wire from step 1) and run it to your VVt light
6) Connect the other side of the light to your ground
How it works.
When the VVT is connect to ground, it will be on the whole time regardless of what the ecu is telling it, because it wont be
connected to the ecu at all. When it is connected to nothing, it wont work at all. And the other option is having it controlled
as normal by the ecu.
The Switch works back to front - when it is switched to one side, it will connect the wire opposite to the side it is switched.
So your "VVT ON" position will be switched to the left (going by diagram) your "VVT OFF" will be middle and the "VVT AUTO"
(ecu controlled) will be right.
The light is fairly staright forward - when the ecu or you activate the VVt the light will turn on. LED lights are great but are
difficult to use (resisotrs... even then they may blow). A normal 12v bulb would be the easiest, as you can wire it straight in.
lotstodo
Postby lotstodo » Wed Feb 16, 2005 6:56 pm
Ok diagram came out messy as (it doesnt look like that) if you want it i can email it to you. Very straight forward non-technical diagram.
lotstodo
Postby LEV_101 » Wed Feb 16, 2005 7:42 pm
hey ... wanna ask something about the resistor... does it matter how or where i put it ... i just soldered it straight onto the led ... is that ok ... :?
LEV_101
also do we need a 3 way switch ... what for ... i dont get it ??? :S:S:S
LEV_101
Postby lotstodo » Wed Feb 16, 2005 8:15 pm
No you dont need the switch, skip it if you dont want it. All it does is let YOU control the VVT rather than having the ECU control it. With the switch you can have it on all the time, off all the time or let the ECU control it as normal.
lotstodo
Postby dotdog » Wed Feb 16, 2005 8:53 pm
Just a quick question, does this work on vvti on the black tops?
Daily Ride - 00 Subaru WRX STi RA 12.7@113
Project Car- 89 Toyota Starlet Turbo S 95.1kws
Ex Ride - 85 Toyota Starlet Si with 4efte, 1990 Nissan Pulsar GTiR 150Kw/atw, 97 Toyota Levin BZR
My Profile: http://toyspeed.blakjak.net/profiles/profile.php?id=589
dotdog
Postby JT » Wed Feb 16, 2005 9:07 pm
dotdog wrote:Just a quick question, does this work on vvti on the black tops?
No and Yes.
Blacktops don't have VVT-i they have VVT so the switch works exactly the same. Theres a few guys with ae111's on here that've had one working.
BTW, the switch does nothing if you are running a standard engine and ecu. I played with it in my ae101 20V on the strip and having it on between gear changes makes no difference as the ecu does a perfect job. Same with when you plant the boot in first. Comzo, how did you come up with that graph? Who measures the angle of their throttle position :roll: Im sure its not auto on after 6400 either, I had mine to redline, albeit not very quick, without activating vvt.
JT
Postby dotdog » Wed Feb 16, 2005 9:15 pm
Im sure i read somewhere that the black tops were vvti, oh well my bad, so what is the diff between vvt, and vvti?
dotdog
Postby B1NZ » Wed Feb 16, 2005 10:07 pm
yes it works on a blacktop, i had one for a while
only prob is i put a 3000mcd LEd in which lit the inside of my car up like a blue xmas tree at night, can be quite distracting and depending on where you sit - blinding haha :lol:
Subaru GF8 Wagon
B1NZ
Postby LEV_101 » Wed Feb 16, 2005 10:27 pm
LEV_101
Postby AceSniper » Thu Feb 17, 2005 4:43 pm
dosnt matter were the resistor is... can be on the neg or pos, just has to be around the right way tho, just like the Led (long an short leg)
AceSniper
Postby Dr-X » Thu Feb 17, 2005 4:46 pm
AceSniper wrote:dosnt matter were the resistor is... can be on the neg or pos, just has to be around the right way tho, just like the Led (long an short leg)
Eeer, no it doesnt.
Dr-X
Postby dotdog » Thu Feb 17, 2005 5:12 pm
Yip ya right there Dr X, resistors can go any way, they are not polarised
dotdog
Postby AceSniper » Fri Feb 18, 2005 5:24 pm
:roll:
AceSniper
