Noisy Coil-overs
Noisy Coil-overs
Postby Flyboy » Thu Feb 17, 2005 10:23 pm
Are COil-Overs usually very noisy in operation?
Flyboy
Postby dotdog » Thu Feb 17, 2005 10:29 pm
I had Tein Coilovers in my old GTiR and they were quite as, no noie what so ever
Daily Ride - 00 Subaru WRX STi RA 12.7@113
Project Car- 89 Toyota Starlet Turbo S 95.1kws
Ex Ride - 85 Toyota Starlet Si with 4efte, 1990 Nissan Pulsar GTiR 150Kw/atw, 97 Toyota Levin BZR
My Profile: http://toyspeed.blakjak.net/profiles/profile.php?id=589
dotdog
Postby Flyboy » Thu Feb 17, 2005 10:35 pm
ive got Teins in the Trueno.... Theres lots of rattling and squeeking... the backs hiss when they go over bigish bunps...
Flyboy
Postby dotdog » Thu Feb 17, 2005 10:44 pm
The teins rattled my pulsar to bits, but the shocks never made any sound
dotdog
Postby Dr-X » Thu Feb 17, 2005 10:50 pm
My mate has teins in his S14, fairly noisey over bumps and stuff, slight hissing, odd creak, etc.
Dr-X
Postby Flyboy » Thu Feb 17, 2005 11:20 pm
Is it bad if theyre excessivailly noisy? I cant tell whether the teins are noisy or the rest of the suspension...
Flyboy
Postby Flyboy » Thu Mar 03, 2005 5:45 pm
Found the problem..... Not the suspension at all... The engine mounts instead!!! :lol:
Flyboy
Postby TRDWGN » Sat Mar 05, 2005 6:18 am
most coilovers are always going to be noisier than factory set-ups due to the simple fact that spring rates are usually a lot firmer and linear rate whereas factory springs usually have some form of progressive rate, also a serious coilover usually has little in the way of rubber isolation in it so you have a much higher level of NVH transmission through shock and spring and then through into car body. In a standard setup most top plates have a high portion of rubber in them likewise the spring sits in a rubber isolater top and bottom all of which is usually redundant in a set of coilovers
TRDWGN
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 13 guests
