Spring installation on AE92 FXGT
Postby gordon77 » Wed Feb 23, 2005 10:26 pm
ok the car is way to low thanks to the previous owner compressing the origional springs :evil:
i am looking at getting new jamex springs for the car basically to tighten things up and raise it a little. few questions....
has anyone else had jamex springs in thier AE92 that could send me pics??? gdear@pasound.co.nz
also installation... as i will be getting the springs through a mate and i cant install them so i was wondering what sort of money id be looking at to get them installed??? i was quoted $50 + GST per corner by someone and that seems a tad over the top to me....
thanks ppl
What is RR?
gordon77
Postby AE85coupe » Thu Feb 24, 2005 1:38 am
$50 per corner is crazy, usually its about $80-$120 for the lot, or you could just borrow some spring compressors and do it yourself, its not that hard
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby ee904age » Thu Feb 24, 2005 7:41 am
Or but some spring compressors, you cand gat a pair for about $40. Its not a hard job to do, Im sure someone with a little more time can explain it.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby gordon77 » Thu Feb 24, 2005 8:50 am
yeah i know it can be done but i have heard a few horrible stories of springs popping out and flying into other cars etc :twisted: and also the suspention is what holds my car on the road so id rather not do it myself.
i have the money to get it done by a professional so why not???
can anyone recomend any places to get these springs put in??
What is RR?
gordon77
Postby Dr-X » Thu Feb 24, 2005 9:13 am
How could the springs fly out? They're macpherson coil over design aren't they?
Anyways, dunno anyone in auckland, but a good mechanic or tyre shop should be able to do it in 45mins, so dont pay more than $75-$100.
Dr-X
Postby pervert » Thu Feb 24, 2005 9:30 am
Too low...is that possible???
pervert
Postby gordon77 » Thu Feb 24, 2005 11:40 am
well it is to low . . . 90mm above ground (to lowest structural point) it becomes a pain in the ass when you have more than one person in te back... the body roll is huuge when cornering.... list goes on
What is RR?
gordon77
Postby Mr Revhead » Thu Feb 24, 2005 12:36 pm
yes compressed springs are baaaad.
and yes springs flying out and damaging ppl and propety can and does happen. thats why good correctly fitting spring compressors are a must.
Postby ee904age » Thu Feb 24, 2005 12:47 pm
gordon77 wrote:yeah i know it can be done but i have heard a few horrible stories of springs popping out and flying into other cars etc :twisted: and also the suspention is what holds my car on the road so id rather not do it myself.
I wasnt meaning spring compressors as in permanently compressing the springs, I was talking about the compressors you use to remove/install the old/new springs from the struts.
90 SW20 N/A - Sold
ee904age
Postby Disinfo » Thu Feb 24, 2005 3:31 pm
I had some Jamex 50mm springs in my Integra - IMO they're way too soft.
Disinfo
Postby MacrosSiR » Thu Feb 24, 2005 3:42 pm
hmm my jamex springs don't seem soft at all.
MacrosSiR
Postby ChaosAD » Thu Feb 24, 2005 8:12 pm
Jamex are known to be soft . but the ride quality/handling of certain brand depends on the car theyre fitted to. Best to ride in a car (same model) that has the springs you want before buying them if you can.
ChaosAD
Postby gordon77 » Thu Feb 24, 2005 10:41 pm
well my mate has an AE82 FXGT that has jamex springs and it seems to be good to that car... my car being a little heavier i would imagine to be fine too???
has anyone had jamex springs in thier AE92 that can enlighten me :)
What is RR?
gordon77
Postby THA SHZ » Fri Feb 25, 2005 9:17 am
Dont forget to get ur wheel alignment after doin your springs aswell pm me wen ud like to do it and i can do it for u if u like 8) Also wot r ur shocks like ? One of the worst things is trying to hold up a shock absorber shaft while it keeps slippin dwn as its rooted :D
THA SHZ
Postby Ae92typeX » Fri Feb 25, 2005 9:38 am
also, just to note, on ae92's the front brake hose has to be removed as it goes through a bracket attached to the shock (unless you grind the bracket off- which a mechanic wont/shouldnt do) so that also means bleeding the breaks and a little more labour time...still, if you have not done before, good time to get it done!...
Ae92typeX
Postby THA SHZ » Fri Feb 25, 2005 10:30 pm
or u can put a small cutt in the bracket and bend it out of the way and then bend it back into place wen u put it back 8)
THA SHZ
Postby gordon77 » Sun Feb 27, 2005 12:19 pm
THA SHZ wrote: Also wot r ur shocks like ? One of the worst things is trying to hold up a shock absorber shaft while it keeps slippin dwn as its rooted :D
well thats one thing i just thought about. because the car is so low i am thinking that the shocks must be shortened.... how do i check if they are shortened and if they are would it still be alright to put the springs on?
the other option it jst to go get some kyb shocks but id rather not because of the cost factor
What is RR?
gordon77
Postby THA SHZ » Mon Feb 28, 2005 9:41 am
look for ne welding marks but if ur keepin the car than the extra shell out now on the shocks should surely be worth it , i can do u kybs or konis or woteva u like and at a good price so let me know if u wana get teh package , but in my opinion is worth the little extra now rather than later and the handling of the car will change dramatically. :D
THA SHZ
Postby pervert » Mon Feb 28, 2005 10:48 am
I'm starting to enjoy the nice bouncy ride my compressed springs offer.
As for 90mm being too low... :lol:
Thats just getting started...
Anyway, you could always get custom made springs...?
As for the shocks being shortened, not nessecarily, my VR4 sat 65mm off the ground at its lowest point with standard shocks, and the springs were still fully captive.
pervert
Postby gordon77 » Mon Feb 28, 2005 10:36 pm
pervert wrote:As for the shocks being shortened, not nessecarily, my VR4 sat 65mm off the ground at its lowest point with standard shocks, and the springs were still fully captive.
im just going off what a few suspention ppl have told me... :?
heres an argument im sure has been battered before on this forum but lets bring it up :twisted: :twisted: ... for an AE92 FXGT that is having jamex 50mm springs fitted what would be the best bet in the way of shocks between kyb, koni, and munroe. dont go into platforms or ajustables....
THA SHZ: you have a pm 8)
What is RR?
gordon77
