best eng conversion for a ke30?
Postby mister two » Thu Feb 24, 2005 4:58 pm
Hi my brother is looking at doing an engine conversion in his ke30.
My mate had a 1600 mazda turb engine(out of bmfr) that he was gonna try and fit because he could get the engine cheap and it would be something a bit different, however he sold it a couple of days ago...
So now he needs another cheap(ish) option for a decent engine to chuck in.
(doesnt want a 5k or anything shit like that and probably something a bit better than a 4age)
I said a 12a due to bang for buck, no computer to worry about, ease of modification, resale value at the moment.
Other than that there is the 4agze? Are these any harder to fit than just a 4age? then there is the issue of what gearbox, t50, w55 etc...
3tgteu, but these are getting quite old now
so what is the best diff to use for a something like this?
Fuel system upgrades, brake upgrades, etc...
I have seen the page posted here about engine conversions to keXX cars but it is quite unspecific.
Are there any good sites that you guys can direct me to, with quite specific details on what is required?
By the way he is an engineer/fitter & turner so would be doing most if not all of the work himself so labour costs are non existant (except maybe auto electrician)
Cheers for any help
Current ride = suggestions welcome
Previous rides = 89 BFMR 4wd Sedan, 73 Fiat 124 Sport CC Coupe, 71 ke26 wagon, 1990 mr2, 1988 rolla hatch, and a cough cough.. sigma
I can't be without my car, even when i'm in the club I drive to the bar!
mister two
Postby deaf_rattle » Thu Feb 24, 2005 5:06 pm
seriously, i suggest a lexus v8 conversion
engine you can pick up for $1g with loom etc, then whatever box you are going to use, whether the factory auto(my suggestion) or w series box.
nice light engine, with plenty of potential.
197kgs of alloy v8
skids aplenty.
$2g (approx) would see it in and running
Postby mister two » Thu Feb 24, 2005 5:28 pm
$&#$% now that would be crazy!!! so what box bolts up to that? dont think he would wanna go auto, is it just a w5X or does it need somethin more hard out?
realistically i think that it might be too much power, but hell it would be fun :twisted:
wouldnt that be a bitch to cert, by comparison to a 'humble' 4ag(z)e/12a/3tgteu?
surely it would require a whole lot of other (serious) mods to make it safe.
PS: love that animated gif in the signature!!!
mister two
Postby deaf_rattle » Thu Feb 24, 2005 5:36 pm
Hey
well they dont have too much power from factory 194kws at the fly.
W series box should handle the jandle for abit (careful driving), but you would be better off with a late model w58 from a jza80 or a r154 box.
Or just have a good supply of normal w series boxes.
The auto is my pick as its plenty strong enough, but then you need to play around abit if you run an aftermarket ecu.
Id say if the chassis is good enough for a high powered 4agze then the 1uz would be fine, probably weigh similar weight to the 4agze too.
www.lextreme.com
check that out.
Postby ee904age » Thu Feb 24, 2005 9:00 pm
If he decides to go with a 4AG, I can give hime a hand to wire it up.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby evil_si » Thu Feb 24, 2005 9:14 pm
wire the 1uzfe auto as manual shifter, been done before and it works very well, smoothest manual youll ever drive :lol:
evil_si
Postby AE85coupe » Thu Feb 24, 2005 9:45 pm
deaf_rattle wrote:$2g (approx) would see it in and running
dunno about that one mate, 2g is a tad too cheap for that sort of conversion
don't forget custom gearbox and engine mounts, also a custom driveshaft, and a custom diff mounts for the hilux or AE86 diff or whatever you use that will handle the extra power, then there is wiring which is never cheap or easy, don't forget the fuel system, all new lines and pump, oh and a surge tank setup, then you get to the brakes, you will need larger front brakes to get a cert, so AE86 struts or something, and also probably a larger brake booster, if you go for a w series box you will need a bellhousing made up to suit, oh and buy a new clucth kit etc, also need to setup your pedal box for hydraulic clutch, and get hold of a clutch slave and master cylinder as well, then there is the fact a ke30 is and old car, the steering box system it has will get very sloppy, which means replacing pitman arms, tierods etc. as well (unless you want to change it to rack and pinion steering)
so really a ke30 with a 1uz.. for 2g... don't see that happening
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby deaf_rattle » Thu Feb 24, 2005 10:22 pm
i said in and running, of course he would need to sort out the diff etc, but you could have it in and driving for $2g
unless you think you know better? :lol:
Postby evil_si » Thu Feb 24, 2005 10:37 pm
[quote="deaf_rattle"]i said in and running, of course he would need to sort out the diff etc, but you could have it in and driving for $2g
quote]
i agree,
kinda wish we had of gone down this track with my flatmates ke30
evil_si
Postby AE85coupe » Thu Feb 24, 2005 10:48 pm
$10 says you can't have a Ke30 with a 1uz in and running for 2g
unless you have some really really good hook ups for cheap parts etc. (full respect if you do though :D )
Details of car here
AE85coupe
Re: best eng conversion for a ke30?
Postby deaf_rattle » Fri Feb 25, 2005 8:39 am
Cheers for any help
maybe if you read, and werent so stupid, you could work things out for yourself.
give me 2k and ill get a 1uz in my car and running
bah
Postby ezy10s » Fri Feb 25, 2005 9:03 am
you couldnt even keep your 7m running fool!
even with all the help people tried to give you- i suggest to those who havent done a 1uz conversion they shut their pie holes.
Member #244
ezy10s
Postby mister two » Fri Feb 25, 2005 9:17 am
alright kids, dont get ya knickers in a twist :wink:
as far as all the mounts and engineering he can do that and probably has hook ups for getting stuff cheaper. so i suppose it may be viable, but i think that the engine and gearbox and other parts may add up, but that happens with any conversion though.
any other suggestions? just throw some ideas in the air, doesnt have to be toyota
mister two
Postby deaf_rattle » Fri Feb 25, 2005 9:36 am
ok glen, if you are going to be a knob about things.
the 7mgte not running is not my fault (crap example to start with)
its just about going, and anyway whats that got to do with anything.
And obviously you have forgotten my mates 1uz super charged ma61, which i helped out with.
get off your high horse and get over yourself.
Postby wde_bdy » Fri Feb 25, 2005 10:19 am
Why not try something basically factory?
I would suggest a 3T pushrod motor. Bump compression, wild cam, big carbs and a set of extractors. It was a factory fitment to the *E3* shell anyway, and very few people stick to NA these days.
Callum
wde_bdy
Postby mister two » Fri Feb 25, 2005 10:42 am
yeah i had a 3t in the 26, but what is the point? costs too much to get anything decent out of an old shitty motor like that.
there is a reason that not many people stick with n/a.... i think it is boost :wink:
he'd wanna start with a solid base with lots of room for improvement, things start out feeling powerful but ya get used to them and wanna bump up the fun 8)
cheers, for the input everyone... anyone agree on the 12a option?
mister two
Postby jeremiahnz » Fri Feb 25, 2005 11:04 am
A mate and I are currently working on a ke30 and are basically trying to make the same decision. It has pretty much come down to a custom turbo setup on a 4age or the 12a.
So far we haven't really worked out what we are going to do in terms of driveline. From what I know (which isn't a lot) there is nothing in terms of diff/rear axle that you can just bolt in.
Here is a page with some info on doing the rotary conversion on a KE70. It may be useful.
http://www.rotor.tk/
jeremiahnz
Postby Draizuh » Fri Feb 25, 2005 11:11 am
what about a SR20DET or a RB20?
Find a skyline some rice boy has crashed and salvage parts heh.
my mates got one in a Mk3 Cortina. goes hard.
12a would be mean. but heaps of people do that. i think the Nissan engine would be mint.
Draizuh
Bahahahahahaha
Postby ezy10s » Fri Feb 25, 2005 11:46 am
deaf_rattle wrote:ok glen, if you are going to be a knob about things.
Well doesnt take much to get you going now does it!- high horse?! im not the one with 2 cents for everything. 2k for a 1uz conversion- hell i got 2k for ya to do me a conversion. i think before poeple start throwing numbers round willy nilly they should actually count up the cost of parts on their fingers and toes.
Member #244
ezy10s
Postby AE85coupe » Fri Feb 25, 2005 11:57 am
deaf_rattle wrote:
Cheers for any help
sorry somehow i missed the part where he says he can get parts at super super cheap prices
i must be a complete idiot, and obviously you in your great wisdom knows so so much more about this than i do
but perhaps you should learn to admit that you may have under estimated the cost of this kind of conversion just a wee bit, its ok mate, people make mistakes sometimes, i know i do
Details of car here
AE85coupe
