4agte problems :O help!!
Postby 1598cc » Mon Feb 28, 2005 7:59 pm
having some problems gettin the car running again.. have just replaced AFM and hasnt helped at all..
symtoms:
start car, and itll die.. if i start the car and give it gas, itll rev up, then want to die again.. i can keep it running like this tho.
also, when my foot is down and i bak off, the car will keep reving for say almost a true second.. (0...1) then die off again.
i checked ecu for codes and:
Code 12
have had a fiddle by hand with the tps and that aint help.. its not set 100% correctly at all, but i just fiddled with it while it was running.
also, occasionally when i turn it to ON, the check error light will blink rapidly for ages.. not showing a specific code and will blink double the speed it would when putting out a code..
im sorta thinking the ecu has fukt out, but cant see why it would..
any help would be great!!!
1598cc
Postby vvega » Mon Feb 28, 2005 8:08 pm
um how are you checking the codes
and count the number of blinks pauses and post thgem up
v
vvega
Postby 1598cc » Mon Feb 28, 2005 8:38 pm
counting them as you would. (i do know how to count the codes)
just the one code that blinks for ages seems weird
1598cc
Postby Mr. Mainstream » Mon Feb 28, 2005 8:41 pm
no leak with the intake or BOV?
75 MK2 Ford Escort L 2.1L
Various Others
Mr. Mainstream
Postby Lloyd » Mon Feb 28, 2005 8:49 pm
So what codes what it spitting out?
Postby 1598cc » Mon Feb 28, 2005 9:11 pm
Code 1 and code 2
Ive read on sites that code 1 is for normal operation, but then it comes up with the code 2.
And sometimes when turning the car to ON, itll just blink rapidly as said above
Cheers for the replies guys!
1598cc
Postby 1598cc » Mon Feb 28, 2005 9:38 pm
btw: anyone gotta spare AFM 4agze ecu i can try?
1598cc
Postby vvega » Mon Feb 28, 2005 9:42 pm
i have one you can buy :D
v
vvega
Postby 1598cc » Mon Feb 28, 2005 10:02 pm
yeh see im broke as fuk always, being a student and all. if it solves the problem id buy it, otherwise im just guna have to find one to try
where bouts you located?
1598cc
Postby 1598cc » Mon Feb 28, 2005 10:03 pm
1598cc
Postby Fred » Tue Mar 01, 2005 4:59 pm
ive got this exact same problem at the mo. be interested to see what happens, thinking in my case its a one huge hole in the plumbing and the throttle body arrangment/idle control etcc. who knows will have to change one thing at a time to see what fixes it
White Trueno ae92, 4agte
172kw atw and as bazda put it "lowest reading dyno in auckland"
http://toyspeed.blakjak.net/profiles/profile.php?id=672
http://www.cardomain.com/ride/2124212/1
Black and Gold Trueno ae92, 4agze
14.6@152 (hmmm thats a .69)
http://www.cardomain.com/ride/2160441
Fred
Postby vvega » Tue Mar 01, 2005 5:53 pm
te awamutu
vvega
Postby toyonut » Tue Mar 01, 2005 6:04 pm
Have you checked all vacuum lines and pipes for leaks and correct routing?
toyonut
Postby CAMB01 » Tue Mar 01, 2005 6:38 pm
Have you at all checked your ignition timing, just wondering, some people tend to forget that one.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby 1598cc » Tue Mar 01, 2005 7:01 pm
think ive seen your car around fred.
ive had a quick look at all vacuum piping and all seems to be well.. i cant even drive the car which sux bad, as ive wired up all the extra injectors so i can run more boost
how bad is yours fred... mine has got worse over time; it initially started missing, then now i cant even keep the idle half decent with my foot.. itll either go full throttle or die.
have you checked your ecu codes?
1598cc
Postby vvega » Tue Mar 01, 2005 7:04 pm
nothing wrong with driving with full trhottle :D
sif
v
vvega
Postby 1598cc » Wed Mar 02, 2005 8:03 am
any other info.. im just wondering why it keeps climbing in RPM even when i bak off the throttle .. the throttle cable definatly aint sticky either 8O
1598cc
Postby Fred » Wed Mar 02, 2005 11:21 am
mines got a few more things wrong than urs i think.
- start up sometimes itl just start then cut out immediately
- other wise it will start no problem and just free rev like at 3 grand
- wont come down from that even when warm etc may come down to 2.5 or 2 if lucky
- when back of throttle it free revs up like half or a full grand
- when just rolling along in nuetral the revs consitantly drop up and down by .5-1 grand
hrmm what else............. all i can think of for now
When did the sc14 conversion did very average piping just to get it going will get it front mounted properly within next fortnight so hopefuly thatl fix sum of the problem and redo all the vacum hoses etc at the time back to their original state and think that the fuel pressure regulator is absolutly nakered and think need a new throttle body
Fred
Postby Fred » Wed Mar 02, 2005 11:22 am
o yea and mines missing too
Fred
Postby ATAl » Wed Mar 02, 2005 11:46 am
That sounds like the classic symptom of a vacuum hose leak, double check that they are all connected properly and there are no holes in any of the hoses.
If you can get it to run long enough have a listen in the engine bay for any hissing sounds coming from any of the vacuum hoses - easiest way to find a leak.
ATAl
