Oil Cooler kit on an MR2 SW20
Postby mister_two » Thu Mar 03, 2005 12:58 am
lookin to put a Trust oil cooler kit on the two, any idea how easy or hard it is? cheers :)
mister_two
Re: Oil Cooler kit on an MR2 SW20
Postby anthonym » Thu Mar 03, 2005 3:49 pm
mister_two wrote:lookin to put a Trust oil cooler kit on the two, any idea how easy or hard it is? cheers :)
The Trust kit won't fit on your car Nan, it's for the gen III onward. You can make one up, but IMO it wouldn't be worth it unless you are planning serious HP mods.
anthonym
Postby FLAWLES » Thu Mar 03, 2005 5:17 pm
wouldnt be worth it? y is this
im asking due to me using one on my 4ag-te and thought i i can keep the oil cool i would get a good gain in hp. + talking o a a-grade mech mate that i now he said it would br=e a dam good idea
help
FLAWLES
Postby anthonym » Thu Mar 03, 2005 5:52 pm
FLAWLES wrote:wouldnt be worth it? y is this
help
I meant it wouldn't be worth it on a gen 1/2 SW20 with basic mods as it's neither cheap nor easy to do, and the stock oil cooler is OK. With he exception that the oil temp does climb after extended thrashing, so if you regularly did this it might be worthwhile.
An NA engine that has had a turbo bolted onto it would be a different story. You would be unlikely to get a noticable gain in HP but you will improve the efficency of the oil (depending on how hot it's getting) and you may reduce the detonation threshold.
anthonym
