18"'s on AE101 corolla
Postby GTCRSHR » Tue Mar 08, 2005 2:19 pm
Hi guys just wondering if any one has done this before
and if so...
what modifications were done to fit if any and how was the actual ride
can you still turn the wheel with out to much problems ?
what size tyres diid you use
if any one has any hits / tips for me muchly appreciated
Nothing to see here ...
GTCRSHR
Postby Distrb » Tue Mar 08, 2005 2:30 pm
have investigated this previously, and i seriously doubt you'll get a set of 18's on there with tyres that will fit under your spring seats (at least in the rear)
width of the rim is gonna be a main factor, theres only a small selection of rims that are made in 18x7. my 17x7s just fit under rolled guards when the springs are fully compressed.
could run into all sorts of problems with your turning circle/scraping
the only way i could see it happening was if you had a set of coilover suspension (removes the spring seat problem) and if you got a decent flared guard setup and had a set of rims with an uncommon offset
Distrb
Regular Poster
Postby GTCRSHR » Tue Mar 08, 2005 2:44 pm
hey andrew cheers for that ... i plan to get lowering springs / shocks as well depending on how the height thing works out
i was planning on 18x7.5 if i can find them
but 17x7 +lowering looks like the way to go i want to try keep the car as moveable as possible and as usable as possible (eg getting over driveways and bumps stuff like that)
GTCRSHR
Postby Distrb » Tue Mar 08, 2005 2:58 pm
GTCRSHR wrote:hey andrew cheers for that ... i plan to get lowering springs / shocks as well depending on how the height thing works out
distance between the ground and car wont be much of an issue... the main will be the distance between the rims and parts of the vehicle.. you'll actually gain ground clearance with a set of 18's as opposed to 17's...
other thing you have to take into account is the rolling diameter of a set of 18's and tyres as opposed to the factory specs. starts to become a warrant issue when the rim size increases that much over factory...
i wouldnt do it for the sheer cost and hassle when you can fit a set of 17's that look good and are relativly practical (as practical as 17's and low profile tyres can be on the road) for about 1/2 the cost
Distrb
Regular Poster
Postby Rob_GTZ » Tue Mar 08, 2005 4:42 pm
Distrb wrote:have investigated this previously, and i seriously doubt you'll get a set of 18's on there with tyres that will fit under your spring seats (at least in the rear)
Really? I think you need to investigate things a little bit Harder!!
Below is my Flatmates AE101 FX-GT, the wheels are enkeis 18x7 (+40 offset) with 215/35/18 tyres all round. Suspension is Springs compressed 60mm with all 4 shocks shortened. As it sits in the photo is with no people in it, with 4 people the back wheels are well up in the guards
Rob_GTZ
Postby GTCRSHR » Tue Mar 08, 2005 4:45 pm
and how does it drive ... can it still turn corners and whats the rubbing like
both inside the wheel and whre the guards are
GTCRSHR
Postby Distrb » Tue Mar 08, 2005 4:45 pm
thats rather interesting...
reason i say that is because i tried on a set of 18's with that size tyre, and i couldnt get them on past my spring seats as the diameter was too big
but that is cool! 8)
Distrb
Regular Poster
Postby GTCRSHR » Tue Mar 08, 2005 4:46 pm
i wonder if the superstrut affects anything ? as that one in the picture in non superstrut (from the sticker)
GTCRSHR
Postby Distrb » Tue Mar 08, 2005 4:47 pm
GTCRSHR wrote:i wonder if the superstrut affects anything ? as that one in the picture in non superstrut (from the sticker)
who knows, mine isnt superstrut, so going by Rob_GTZ's post, they should have fitted....
i stand corrected
Distrb
Regular Poster
Postby Rob_GTZ » Tue Mar 08, 2005 5:03 pm
doesn't ride too bad really, remembering that anything on compressed springs is never going to feel that great!
As for rubbing, umm well lets just say that the front inner plastic guards are pretty much non-existent now, they they don't really matter. No rubbing on the outer guards as such front or rear. There was a small amount of "massaging" :lol: required on the rear springs seats
Rob_GTZ
Postby Dodgy Guy » Tue Mar 08, 2005 6:14 pm
17's will look heaps better with low pro's anyways :)
Dodgy Guy
Postby Distrb » Tue Mar 08, 2005 6:30 pm
Rob_GTZ wrote:There was a small amount of "massaging" :lol: required on the rear springs seats
well that makes sense then :lol:
Distrb
Regular Poster
Postby Lloyd » Tue Mar 08, 2005 7:09 pm
If you're going to do it, dont go for 7.5 inch wide. 7 in about all you'll want on a car like that anyway. Offset is really the key to getting them in there. I've got 18x7s with 215/35/R18s on them without guards rolled, lowered and they fit in no trouble except for the massaging of the spring seats.
Postby Rob_GTZ » Tue Mar 08, 2005 8:58 pm
Actually sorry i was telling a lie there, no massaging was required at all, the key is just getting the correct offset. I was confusing it with his previous car that we had to bang the spring seats around (AE80 Corolla)
Rob_GTZ
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
