4age turbo manifold torque setting? (blown gasket)
Postby ~SlideWays~ » Wed Mar 09, 2005 12:00 pm
Yep ive got a blown exhaust manifold gasket, this engine has a custom turbo manifold jobbie. No doubt it'll be a standard torque setting for all 4age exhaust manifolds but what is it?
I just dont want to have to do it again :lol:
~SlideWays~
Postby ee904age » Wed Mar 09, 2005 12:35 pm
250kg/cm aka 18ft/lb aka 25n-m.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby gdsup » Wed Mar 09, 2005 1:02 pm
dont use acl gaskets as they will blow out real quick, try genuine, also hold a straight edge along the face of the manifold, it may be warped, in which case best thing to do is get a machine shop to skim it
gdsup
Postby dohca » Wed Mar 09, 2005 1:13 pm
i had the same problem
the acl one died within hours
stock toyota one has lasted for ages
stock toyota one costed me like 25$
dohca
Postby ~SlideWays~ » Wed Mar 09, 2005 3:02 pm
Thanks guys.
Got it off and looks like it wasnt blown but wasnt torque'd down properly or isnt perfectly flat as u said gdsup. I put a set level (bubble type) on and it seems fine if not anextremely slight variation from on side to the other.
EDIT:
slight variation = roughly 0.5mm (is that enough to warrent a skimming?)
~SlideWays~
Postby Lloyd » Wed Mar 09, 2005 6:54 pm
If its not dead flat then probably get it machined flat. Got mine machined and put another ACL gasket in (go the $2.49 gaskets :D) And it lasted about 2 weeks. Decided to blow on my very first run down the track actually :( Genuine are about the 27 mark but have metal rings around each port rather than the ACL ones which are basically the shape cut out of the back of a Weetbix box.
