B_giB wrote:
but there are devices out there... i think gizzmo do one, but dont qoute me on that
hare wrote:reason why I want to do it is I have race cam on the car,I can feel the power still can go when REV cut on it,.....I don't really want to totally remove the rev cut since as you guys said it's quite dangerous if I miss gear,but want it go a little bit more than the factory rev cut.
vvega wrote:if you really wanna rev it harder i hope you will consider a rod upgrade to something that will accept that higher stress reliably
HRT wrote:vvega wrote:if you really wanna rev it harder i hope you will consider a rod upgrade to something that will accept that higher stress reliably
Especially in a blacktop. Mmmm.... toothpicks. Gotta remember all the other things than need to be replaced to rev much past 8 too such as valve springs (anyone know what the 20V springs are good for?)
PS, when is your birthday vvega? Might get you a dictionary or something
ezy10s wrote:there is/was a blitz ecu(to suit blacktop 4age) on trademe which had no speed cut and a higher rpm limit on it(dunno much about it) could be worth a look maybe?
