is there any device can stop the REV cut?
Postby hare » Wed Mar 09, 2005 11:36 pm
want to rev the 20 value for higher rev,anything I can stop the rev cut???
hare
Postby slighty_sykotic » Wed Mar 09, 2005 11:47 pm
New ecu? If the mods don't warrent a new ecu, then ask yourself why you want to up the revs? Its passed its peak power at 8000 grand anyway, just in time to upshift into the meaty part of the powerband.
--Sykotic
slighty_sykotic
Postby B_giB » Wed Mar 09, 2005 11:47 pm
excuse me while i ask why you want to do that...
the reason i ask is that they are there to save the engine from blowing up from too much revs, unless your engine is worked to rev higher than factory, one of the reasons its there is incase u miss a gear and your engine winds right out and then BANG...
/end rant
but there are devices out there... i think gizzmo do one, but dont qoute me on that
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby rwd_mayhem » Thu Mar 10, 2005 9:17 pm
i wish the celica (1990 manual sr) could get to 8000rpm - it gets to the start of the redline (6200) and cuts out - its such bullshit! i know it can go faster if it could just get to at least 7200rpm!
current: 1975 Valiant Regel
rwd_mayhem
Postby matt dunn » Thu Mar 10, 2005 10:49 pm
I am pretty sure that they cannot be removed in toyota's just like toyota's can't be chipped.
Matt
Postby hare » Fri Mar 11, 2005 12:14 pm
reason why I want to do it is I have race cam on the car,I can feel the power still can go when REV cut on it,.....I don't really want to totally remove the rev cut since as you guys said it's quite dangerous if I miss gear,but want it go a little bit more than the factory rev cut.
hare
Postby Silent Knight » Fri Mar 11, 2005 12:36 pm
then get an aftermarket ecu and it get it programmed so that you can make use of the extra power....
Silent Knight
Postby AceSniper » Fri Mar 11, 2005 1:04 pm
is this silvertop or blacktop?
max you wanna rev a standard silvertop is 9k an a blacktop 8500
AceSniper
Postby Fuct Munkey » Fri Mar 11, 2005 7:21 pm
what makes you say that ace?
Fuct Munkey
Postby vvega » Fri Mar 11, 2005 7:58 pm
hare wrote:reason why I want to do it is I have race cam on the car,I can feel the power still can go when REV cut on it,.....I don't really want to totally remove the rev cut since as you guys said it's quite dangerous if I miss gear,but want it go a little bit more than the factory rev cut.
i know raiesing the revlimit itself seems like the eazyest option but....
you have to remeber the extra stress your putting on the engine is doubling with every 500 rpm your moving it
if your motor has not been built to take this additional stress there is a goodd chance that it will fail
also elevated rpm levels can make your cluch malfunction in the way it makes the diaframe release with centrivical force
something else to think on :D
just a bit of interesting bit of info for you to think about
rev's are the most stressful thing you can do to a rod.. in a n/a
if you really wanna rev it harder i hope you will consider a rod upgrade to something that will accept that higher stress reliably :D
v
vvega
Postby Lloyd » Fri Mar 11, 2005 9:34 pm
vvega wrote:if you really wanna rev it harder i hope you will consider a rod upgrade to something that will accept that higher stress reliably :D
Especially in a blacktop. Mmmm.... toothpicks. Gotta remember all the other things than need to be replaced to rev much past 8 too such as valve springs (anyone know what the 20V springs are good for?)
PS, when is your birthday vvega? Might get you a dictionary or something :D
Postby hare » Sat Mar 12, 2005 2:35 am
thanks really much for suggestion,it's a black top engine and we already have aftermarket value spring when fitted the cam on it,we just want to rev a bit high to see what happen seen the engine still want to rev a little bit higher for more power.Also thanks for suggestion for the rob changing!
I know the best idea is changing aftermarket ECU to make it rev higher,but buying a secondhand ECU such as TRD one is quite expensive,.....and it seen only can rev to 8900rpm...we did have a SARD ecu on it before.
Anyway back to the topic,do gizzmo make anything to remove the rev cut or anyone know anything can do on it????? :(
hare
Postby vvega » Sat Mar 12, 2005 8:09 am
lol my birthda funny enogh id the 25th of march :D
wohoo i get a holiday on my bday :D
sorry hare but toyota factory ecu's are fixed in there revlimits
you would need to look toward a aftermarket ecu as toyota uses a soft ignition and a hard fuel cut :(
i can tell you from, experiance that the blacktop will want to rev to 9 and there was uewans 10k 20v as well that pulled all the way to the redline and then some
the stock 20v top end will coap with 10k though the blacktop more so as it has the stiffer valve springs :D
so i think that answers your question
without a replacement ecu you wont rev any higher than stock :(
best of luck
v
vvega
Postby hare » Sat Mar 12, 2005 8:19 pm
thanks,that's all I want to know. :D
hare
ecu
Postby ezy10s » Sun Mar 13, 2005 10:25 am
there is/was a blitz ecu(to suit blacktop 4age) on trademe which had no speed cut and a higher rpm limit on it(dunno much about it) could be worth a look maybe?
Member #244
Gone fishing until further notice
ezy10s
Re: ecu
Postby hare » Sun Mar 13, 2005 1:13 pm
thanks man,we did use SARD one before,it did improve but it can't remove the fuel cut,I except BLITZ one is the same improvement as SARD one,...also for that price I can get a TRD or TOM's one anytime with courier post to nz in three days..... :roll:
thanks for your info!!!!! :D
ezy10s wrote:there is/was a blitz ecu(to suit blacktop 4age) on trademe which had no speed cut and a higher rpm limit on it(dunno much about it) could be worth a look maybe?
hare
heh
Postby ezy10s » Sun Mar 13, 2005 1:35 pm
Yeah true- hey the link ecus have dropped in price maybe hit them up for one?
Member #244
ezy10s
Postby ChaosAD » Sun Mar 13, 2005 4:35 pm
Even if you could remove the rev limiters, would the ecu be mapped that far?
ChaosAD
Postby Lloyd » Sun Mar 13, 2005 4:40 pm
I think that Blitz one on trademe was only to 8500 anyway. Was gonna say about it on here but couldn't find the auction again
Postby vvega » Sun Mar 13, 2005 4:54 pm
the other option id to get a ignition only ecu and tri that link also sells one of those :D
v
vvega
Users browsing this forum: Google [Bot] and 51 guests
