Wastegate on 1JZ.
Wastegate on 1JZ.
Postby Silent Knight » Thu Mar 10, 2005 3:14 pm
I was wondering if anyone from here has every played around with putting a wastegate on a 1JZ whilst it's still using both turbos?
What sorta diferences can you notice etc?
How easy is it to modify the manifold to fit a wastegate on?
Cheers :D
Silent Knight
Postby Silent Knight » Fri Mar 11, 2005 11:59 am
BUMP
anyone....?
Silent Knight
Postby nite b » Fri Mar 11, 2005 4:32 pm
Good idea, but stuff that! Be a fair bit of work involved for minimal gain. Guess would tap into both fact manifolds & port both into one external gate.. Possibly viable on 2jz setup that only has one wastegate as such :roll:
Labour would be easier to do single conversion, but guess cost of manifold & turbo bit extra :(
Nothing wrong with factory twin setup, can get plenty grunt out of em :D
Convert Ltd
The conversion specialist
nite b
Postby Silent Knight » Fri Mar 11, 2005 4:40 pm
Yea I know of people in the US that's done it on a 2JZ and it was a tad of a mission but it was done and works aparently good.
I was wondering if this would be a viable option to do on a 1JZ or just to wait till I go single on it wich shouldn't be 2 terribly long.
And yea I know the 1JZ can get fairly good power out of the stock turbos with a bit of playing around and tweaking here and there but i'm just considering playing around with a couple of different setups :D
Silent Knight
Postby nite b » Fri Mar 11, 2005 5:26 pm
Mean! You got the idea :D
You know what they say, 2 little ones do the job great, but nothing satisfies better than a big fat mutha one... 8)
Convert Ltd
nite b
