clutch install on GT4 celica help..
Postby EVL20V » Thu Mar 10, 2005 8:48 pm
any1 know from experience how tricky it is 2 do the clutch? 4wd mess :lol:
does:
a) engine need 2 b removed?
b) how long would it take?
c) is DIY recommended? :lol:
d) how much 4 clutch (not hard out heavy duty etc) :D
EVL20V
Postby Alex B » Thu Mar 10, 2005 9:03 pm
if its anything like my sprinter then you have to drop out the ottom suspension and drop motor and box out the bottom you need a good 100mm between the engine and suspension tower to leaver the motor off this was case with sprinter you may have more room in da celica my 4wd clutch kit was $450rrp it will be more heavy duty than a 2wd clutch hence the high price.
Postby vvega » Thu Mar 10, 2005 9:08 pm
its motor out
its about 2 days work for a firts timer
and its not for the faint hearted
that gearbox is a heavy as the bloddy engine
so not really recomended if your not bron with a spanner in your hand ...
v
vvega
Postby EVL20V » Thu Mar 10, 2005 9:09 pm
cheers! :D
EVL20V
Postby RedMist » Thu Mar 10, 2005 9:31 pm
I'll pray for you my son.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Zero_Cool » Thu Mar 10, 2005 10:01 pm
wow are you gonna attemp this your self?
Zero_Cool
Postby GT4 20 » Thu Mar 10, 2005 10:28 pm
It is possible to swap the clutch without removing the engine completely - but it is easier to take it out. Not a job for the uninitiated though that's for sure!
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby vvega » Thu Mar 10, 2005 10:51 pm
GT4 20 wrote:It is possible to swap the clutch without removing the engine completely - but it is easier to take it out. Not a job for the uninitiated though that's for sure!
Gary
so you have done this then
how did you get the 2 bolts off the gearbox brace???
just out of intrest :D
ive tried doing it in car 3 times and have had to remove it to make a suscessfull job
considering i can do it in 3- 4 hours now on a jack i consider myself to be not bad at it :D
i know it can be done providing you ommit a couple of bolts when refitting :D
v
v
vvega
Postby GT4 20 » Thu Mar 10, 2005 10:57 pm
Haven't done it myself - but know a couple of people in the UK who have. Don't know the procedure, but I gather you have to remove the transfer case or something like that.
I'm planning on an uprated clutch later in the year and will definately be getting someone else to do it!
Gary
GT4 20
Postby vvega » Thu Mar 10, 2005 11:02 pm
GT4 20 wrote:Haven't done it myself - but know a couple of people in the UK who have. Don't know the procedure, but I gather you have to remove the transfer case or something like that.
Gary
and thats the main plroblen right there
you cant till the motor is out
one of the bolts id blocked buy the block :D
and that transefer case is what stops it from happening :D
maybe they were thinking bout thaking the motor out from the top
anothjer trikky job
you have to remove the pinion gear to get it out from the top and that could be considered buy most to be the tranfer housing ..though its not :D
v
vvega
Postby RunningRich » Fri Mar 11, 2005 8:16 am
It can be done, but as stated, it is easier to drop the lot.
When my ST165 gearbox was repaired under warranty the Gearbox Factory left the engine in.
I believe that the tranfer can be removed in-situ on ST165 and ST185, but I've tried it on ST205 and it definately cannot be done. We had a twin plate clutch installed on a ST205 engine and it took almost three hours just to get the damn gearbox on, this one was just so tight. Removed transfer and fitted gearbox, only to find transfer cannot be refitted due to a rib on the block. What a dog.
I've always found the gearbox drops on it about a minute, otherwise it will take at least 1/2 hour.
My best time to have the clutch out is 2.5 hours from driving the car in. The joys of hoists and air-tools!
Richard
http://gtfour.supras.org.nz
RunningRich
Postby blitza » Fri Mar 11, 2005 10:24 am
ke?
done it, not taking the transfer case off, one axle, left the engine in. in and out two and a half days.
MAD Industries Limited
blitza
Postby vvega » Fri Mar 11, 2005 10:41 am
Just_Juzz wrote:Is the motor mounted the same way as in a normal Celica? with Trans axle gearbox?
The engine doesn't have to come out if this is the case, as this is the same way my engine is mounted.
Take both wheels off, hubs off, but brakes still attached, pop thenaxles out. Alternator and battery out. Clutch cover etc off.
New clutch in, everything back in. BOut 8 hours work
lol
youve never donw one have you :D
you have to twist the gearbox laterally to get...........
i give up
youve all obvuisly done one and have a good indepth knowlage of it
sick of this you tri to help some poor bastard out and you get a bunth of peole who have never done one jumping in saying dofferent
noonder peole get so $&#$% up
v
vvega
Postby vvega » Fri Mar 11, 2005 10:43 am
blitza wrote:ke?
i know it can be done but 2 day ....
whooo
:D
v
vvega
Postby EVL20V » Fri Mar 11, 2005 5:45 pm
cheers vvega, i can get the clutch kit at cost price :D
i shall leave it to the pros, up to them how they attack it :lol:
although these online manuals a dude found are very useful, i cant be bothered DIY 8O
i can manage a FWD/RWD car but a GT4 is outa the question! :lol:
EVL20V
Postby craigt » Sat Mar 12, 2005 3:31 pm
One of the mechanics at my work did a clutch on one last month.
Left the engine in, took 4 guys to get gearbox/transfer case back in.
But the job only took 7 hours. It was charged out at quite a bit more thou!!
If it doesn't fit, force it.
If it breaks it needed replacing anyway!
AE101 4AGZE
KP60 4AGTE project
craigt
Postby Rob » Sun Mar 13, 2005 7:48 pm
Engine out isabout 3 hours on the ground and about 4 back in, easy as. I've done several times.
To get the gearbox off and leave the engine behind just take out the starter and undo the pressure plate through that hole (also the easiest way to put back in, and plate is already centred).
If you are to remove the engine take vacuum switch or sensor off as it WILL break
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Users browsing this forum: No registered users and 27 guests
