does:
a) engine need 2 b removed?
b) how long would it take?
c) is DIY recommended?
d) how much 4 clutch (not hard out heavy duty etc)
GT4 20 wrote:It is possible to swap the clutch without removing the engine completely - but it is easier to take it out. Not a job for the uninitiated though that's for sure!
Gary
GT4 20 wrote:Haven't done it myself - but know a couple of people in the UK who have. Don't know the procedure, but I gather you have to remove the transfer case or something like that.
I'm planning on an uprated clutch later in the year and will definately be getting someone else to do it!
Gary
Just_Juzz wrote:Is the motor mounted the same way as in a normal Celica? with Trans axle gearbox?
The engine doesn't have to come out if this is the case, as this is the same way my engine is mounted.
Take both wheels off, hubs off, but brakes still attached, pop thenaxles out. Alternator and battery out. Clutch cover etc off.
New clutch in, everything back in. BOut 8 hours work
Users browsing this forum: Google [Bot] and 31 guests
