problem with tacho.. i think?
Postby scope » Wed Mar 16, 2005 1:09 pm
hello
i installed a tacho the other day and i'm not sure it's working correctly. if you take the car to 4000rpm it sounds like it's at 7000rpm, it sounds too fast to be 4 grand and doesn't really sound healthy. it's only a 3k in a ke30 but still i think that redlining around 4 grand is a bit low!
what do you think? (i got it hooked up to negative side of coil. i've read to do both but instructions said negative)
thanks
scope
Postby slighty_sykotic » Wed Mar 16, 2005 1:23 pm
Rev it in netural until you hit valve bounce, or untill it sounds like its missing/dying. Then if its doing that at about 4000-5000 rpm then there is something wrong with your tacho, or the way you have it wired up :D.
or get another tacho you know works and temp wire it up next to the other one, and compare.
My 3k in my beach buggie goes to at least 7 with no sign of anything happening.
--Sykotic
slighty_sykotic
Postby minijrocks » Wed Mar 16, 2005 4:13 pm
make sure your wires are touching enough. my shift light works fine at 5000rpm but when i set it at 6 it goes at 6500rpm... :?
minijrocks
Postby z|gen » Wed Mar 16, 2005 4:21 pm
youd be suprised aye..
around 4000rpm sounds a bout right for when its starting to redline - the 3Ks dont go much over 7000rpm.
AE91 SUPERCHARGED COROLLA
z|gen
Postby Fuct Munkey » Wed Mar 16, 2005 9:02 pm
make sure the cylinder select switch is on the right setting. aye neil :P
Fuct Munkey
