GTZ gearbox removal
GTZ gearbox removal
Postby Fandango » Thu Mar 17, 2005 11:08 am
ae92 gearbox removal+swap.. Whats involved? a bitch of a job?
Fandango
Postby edwagon » Thu Mar 17, 2005 5:33 pm
Depends on which motor its got, A series are easy as, E series you've gotta drop the whole subframe to get the north south beam out, but not a big hassle either way. Good luck!
edwagon
Postby evil_si » Thu Mar 17, 2005 5:53 pm
well it obviously has a 4agze,
seeing as its stated its a ae92 gtz.
to be honest its not to bad, ive done a couple, just need a bit of patience,
geoff??
evil_si
Postby Lloyd » Thu Mar 17, 2005 5:59 pm
Easy as once the motor is out of the way :)
Not too bad, what you'd expect from most FWD gearboxes except its got 3 engine mounts on the gearbox
Postby vvega » Thu Mar 17, 2005 8:13 pm
you can do iy in a day eazy as :D
v
vvega
Postby RS13 » Thu Mar 17, 2005 8:19 pm
hah, I got an N12 Pulsar clutch done from jack up to jack down, in 45 minutes.. They are so damn easy to do! Any FWD/RWD clutch should take around 4-5 hours straight for anyone with basic knowledge of their car. Add a day to get the flywheel buffed..
RS13
Postby thaphatty » Thu Mar 17, 2005 8:33 pm
can go without but engine support makes it alot quicker and easier :)
id love to see someone with only basic knowledge of a car do a windom clutch in 4-5 hours :wink:
infact id pay to see it
thaphatty
Postby vvega » Thu Mar 17, 2005 9:09 pm
superstrut ads a whole new dimention to ...oh man it all has to come off :D
v
vvega
Postby Bazda » Thu Mar 17, 2005 10:30 pm
take out the drive shafts, drop the subframe, need an engine support beam to hold the engine inplace once most of the mounts are out and only 1 holding it. then unbolt the gear box.
gearbox
Postby Fandango » Tue Mar 22, 2005 3:54 pm
Sweet, looks like my easter project. :) goody. any gaskets etc I should buy before i get stuck in?
Fandango
Postby Bazda » Tue Mar 22, 2005 4:11 pm
nope
Users browsing this forum: Google [Bot] and 23 guests
