External Fuel Pump
External Fuel Pump
Postby strainy » Fri Mar 18, 2005 2:56 pm
hey im putting a 16v tvis into my ee90 and am wonder where the best place to install the 3L VL commmy fuel pump and how to run the return fuel lines.any help is appreciated
strainy
Postby ee904age » Fri Mar 18, 2005 6:32 pm
Ideally you want it as low as possible without it becoming exposed to damage. Its been a while since Ive had mine but I think theres a space on the passengers side chassis rail somewhere.
I just used the factory feed line for feed and the tank breather for a return temporarily. If you can find an AE92 EFI sedan/hatch at pick a part or the likes then get the lines off that as the setup I used was probably a bit small (6mm feed and 4mm return)
Have you modified the mount and sorted a gearbox for it yet?
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby strainy » Sat Mar 19, 2005 11:36 am
gearbox came with engine.havnt started the swap yet (waiting for easter and collecting parts) which mounts need modifying?anything else i need to know which will make the swap go more smoothly?did u upgrade brakes and hubs?
strainy
Postby ee904age » Sat Mar 19, 2005 12:37 pm
Theres alot more involved than just swapping the engine over.
The engine mount on the drivers side inner guard doesnt line up, it needs to be mved foward about 70mm ish. The AE82 box has bolt on inner CV's where the EE90 has normal circlip type so you will need driveshafts to suit the gearbox aswell.
I never got mine on the road but had it running and semi driveable using the EE90 box, the bottom two bellhousing bolts dont match the 4A block though and the clutch is too long.
And then theres little things like the throttle cable is too long etc.
If had was to convert another EE90 to anything I would use a 4EFTE.
The mounts are the same, stock gearbox will bolt up (but wont last too long) and its will be easier to get more power out of being turbo.
So unless you are prepared for a lot of work, I would use the 4E.
My 2c
90 SW20 N/A - Sold
ee904age
Postby strainy » Sat Mar 19, 2005 3:48 pm
thanks for everything.will give it a shot got plenty of time.
strainy
Users browsing this forum: Google [Bot] and 26 guests
