my radiator
my radiator
Postby GasGuzler » Sat Mar 19, 2005 2:40 pm
my top radiator hose has no pressure in it when it is running, even when i top up the radiator. also noticed that alot of fluid ends up in the over flow.
what is wrong with it?
< Corona GTR >
GasGuzler
Postby Lloyd » Sat Mar 19, 2005 2:47 pm
Are you waiting until it warms up? Might be time for a new radiator cap
Postby GasGuzler » Sun Mar 20, 2005 3:59 pm
radiator cap? how will that fix it, excuse my newbness
< Corona GTR >
GasGuzler
Postby GasGuzler » Sun Mar 20, 2005 4:00 pm
the harder i drive my car and the hotter it gets the boiling sound gets louder
< Corona GTR >
GasGuzler
Postby Rick » Sun Mar 20, 2005 4:08 pm
Go to RIPCO or toyota and buy a new raditor cap they are about $15 try that first.
Postby Lloyd » Sun Mar 20, 2005 4:10 pm
Well the water in your radiator can exceed 100°C. If you've got a buggered radiator cap or one that isn't right for your vehicle then it may not be holding pressure which means the water can boil. If you've got a radiator cap thats holding pressure as it should then the water temp can reach 100°C and not boil.
If that doesn't work then take it to a garage, might be a leak somewhere. Pressure test will show that up pretty quick.
Postby GasGuzler » Sun Mar 20, 2005 4:32 pm
yup sounds like the cap aey, last time i cheaked it the seals in it where abit skrewed.
< Corona GTR >
GasGuzler
Users browsing this forum: Google [Bot] and 25 guests
