ae85/6 steering columns
Postby z|gen » Sat Mar 26, 2005 7:57 pm
hey,
im just wondering if the ae85 and the ae86 steering columns are the same ?
how many splines are these ?
and roughly how much id have to pay to pick one up second hand ?
cheers David
another random question will follow soon :lol:
AE91 SUPERCHARGED COROLLA
z|gen
Postby NZ_AE86 » Sat Mar 26, 2005 9:15 pm
There are a few different types but all take the same steering wheel/bosskit, not sure on the No. of splines but you can put an AE85 column into an AE86.
NZ_AE86
Postby z|gen » Sat Mar 26, 2005 9:20 pm
true, what do you mean by different types ?
are there heigh adjustable ones or something ?
how much is one likely to cost me ? ae85 or ae86, cheapest ?
z|gen
ae85 steering columns
Postby crispy'86 » Sun Mar 27, 2005 9:39 pm
What NZ_AE86 means is the power steer columns are different in length, (fact) the ae85's should be the same length in manual steer but ae85's aren't tilt adjustable LIKE AE86'S. The other option is an aw11 mr2 columnn which looks visually the same. I'm going to try my ae86 column and aw11 columns against each other and see the differences.
WATCH THIS SPACE.................
crispy'86
Postby z|gen » Sun Mar 27, 2005 9:57 pm
im after non power steering, and non adjustable - but il just pull out the angle grinder and solve that part, iv heard that an ae86 will mate quite nicely with an aw11 non p/s rack and pinion steering rack, which im also after.
z|gen
Postby nzae86 » Mon Mar 28, 2005 5:56 pm
crispy'86
I have just picked up an ae85 Trueno that has an adjustable steering column as stock , first one in the 20 odd that I've had, and no it doesn't look like some one has dicked with it , it's non power steer as well.
Your addiction to motorsport can only be cured by poverty!
nzae86
Postby z|gen » Mon Mar 28, 2005 9:06 pm
so how much does a non p/s column and also non adjustable usually sell for ?
z|gen
Postby spencer » Tue Mar 29, 2005 12:42 pm
bugger all just finding one is the trouble. if you find a P/s one for cheap/free the bottom half after the uni seems to be the only difference and looking at a ke70 one it looks like you could swap it on
ms63 crown
spencer
Postby z|gen » Tue Mar 29, 2005 1:08 pm
hmm yeah, all i need to find is someone wrecking an ae85 and il be sorted, have found the majority of the other parts im after - pedal box, master cylinders etc, and have located an aw11 rack and pinion steering rack, just need a new column.
z|gen
Postby wde_bdy » Tue Mar 29, 2005 1:35 pm
Have you thought about just using a KE70 column?
Callum
wde_bdy
Postby z|gen » Tue Mar 29, 2005 2:50 pm
hadnt thought of that, are they the same as the the ae85 ones ?
z|gen
ae85/ae86
Postby crispy'86 » Tue Mar 29, 2005 8:36 pm
NZae86; Gee that's a first!! Maybe someone has put an ae86 column into it at some stage, all the ones i've had/seen are non-adjustable column.
zglen; there is a post somewhere else about doing this conversion but u may have to do a search. Yep the ke70 column and ae85 column are similar, just make sure it's a non-power steer vehicle or you will have to change the lower universal over as callum said
crispy'86
Postby z|gen » Tue Mar 29, 2005 8:46 pm
sweet as..
pick a part mission tmrw for various bits and bobs :)
i dont suppose there is much difference between the ae82 and the aw11 rack and pinion steering setups ?
z|gen
Postby NA Drifter » Wed Mar 30, 2005 1:07 am
I seen an adjustable steering column on an AE85 Levin before. But it didn't say "LEVIN" at the side rubber thing, just "LIME" instate! Is a 2 doors Levin. Also have pocket at the door but no digital clock!
My AE86 have non adjustable steering column. :?
Keith
NA Drifter
Postby spencer » Wed Mar 30, 2005 11:42 am
ke70 coloums are different all together they mount differently to an ae85 I have tried this
ms63 crown
spencer
Users browsing this forum: Bing [Bot] and 7 guests
