ae101 twin exhaust to single
Postby minijrocks » Tue Mar 29, 2005 8:56 pm
Hi, i got my cat removed a while ago and I was having a gander at the back of the exhaust and as it goes into two smaller pipes from the original one. Can i ditch both and just have one single pipe from where it splits into two and just have a straight pipe, no muffler or 'phat pipe'?
minijrocks
Postby Dr-X » Tue Mar 29, 2005 9:52 pm
Sure, you can do whatever you like. Personally, I like the look of the twin exhaust.
Dr-X
Postby minijrocks » Tue Mar 29, 2005 9:56 pm
wouldn't splitting it into two pipes be less effective at releasing the gas? would one pipe have more flow?
minijrocks
Postby Dr-X » Tue Mar 29, 2005 9:56 pm
The ass dyno might feel a difference, but I'm guessing the real dyno would tell you it's an insignificant one.
Dr-X
Postby minijrocks » Tue Mar 29, 2005 10:01 pm
would it make it a little bit louder than it is? just like a little wank factor?
minijrocks
Postby Dr-X » Tue Mar 29, 2005 10:06 pm
You're taking away 2 mufflers, so yep, I'm sure it would be a bit louder.
Dr-X
Postby Mr Revhead » Wed Mar 30, 2005 12:31 am
two 1.5inch holes flow more than 1 3 inch hole.
thats why 2 smaller valves are better than one big one.
hence why mutli valve setups are favoured these days.
