Oil Pressure
Oil Pressure
Postby CAMB01 » Wed Mar 30, 2005 9:15 pm
How do lower the engine oil pressure as it goes into the turbo on a 4AGZE wid a turbo setup?
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Dr-X » Wed Mar 30, 2005 9:19 pm
With a restrictor - a piece with a smaller internal diameter than you oil lines.
Dr-X
Postby wde_bdy » Wed Mar 30, 2005 9:19 pm
Usually there is a restrictor in the feed line to cut the volume of oil going into the turbo.
Callum
wde_bdy
