RS13 wrote:A turbo 4age into a starlet. $5000 isn't going to get you anywhere, you could probably get a standard blue/redtop in and running for $5k, but a turbo takes a LOT more time and money, getting manifolds made up, intercooler setup, the whole lot tuned properly.
You'll need at least twice your budget to turbo it properly, with a reliable setup, and certification.
With your kind of budget, you could easily get a decent rotary in, or maybe a 2TGEU, and certification. I know of a guy here in Chch (1FAT30 for those who may know!) with a KE30, he just spent $5000 on a rotary conversion, JUST getting the motor, getting it installed and wired up, thats not including cert.
For a reliable setup, you'll need:
4AGZE ($1000 - $1200 from an importer)
W55 ($300) with W - A bellhousing ($200)
RWD inlet manifold ($200)
loom + ecu ($300, very limiting)
or Link ECU (in and tuned, $2000)
installation of motor (fuel pump + lines, mounts, $400)
turbo, oil lines, manifold, intercooler, piping ($1000+)
Hilux rearend with LSD ($500)
custom driveshaft ($250)
That gets you going, on the road. Now you need to be able to stop! Throw on some decent brakes, $400. Handles like a bag of sh*t? better get some decent shocks and springs, ($600) or better yet, some coilovers ($800). Got pulled up? Need cert, add another $800 or so. Thats around $7500 so far, with the Link. Then add all the little bits and pieces that you didn't think of.. like servicing the GZE. You could go with the bluetop, it would be a lot cheaper, but it won't be anywhere near as reliable.
And as someone here once said, Cheap, Reliable, Fast.. you can only ever have two!
mite have a talk to glenn as well, hes done a few of these.
3T-Rona wrote:if ur lookin at Mega Squirt ive got a brand new one un-opened in the original box i bought around december-ish not using it as i have a link now, will sell for $300, they cost $350ish depending on exchange rates and then take about 2 and a half months to get her depending on waiting lists.
Users browsing this forum: Google [Bot] and 54 guests
