corona dissy
corona dissy
Postby BENS 8 » Mon Apr 04, 2005 7:42 pm
Can you replace the coil in the dissy on a 3sfe motor. ( ST 191 Corona) Manual says no but Repco lists a replecement.
BENS 8
Re: corona dissy
Postby matt dunn » Mon Apr 04, 2005 7:59 pm
BENS 8 wrote:Can you replace the coil in the dissy on a 3sfe motor. ( ST 191 Corona) Manual says no but Repco lists a replecement.
Yes you can and we do all the time at work as they ( all toyota internal dist coil's) quite a common problem.
Matt
Postby BENS 8 » Mon Apr 04, 2005 8:31 pm
Thanks Matt, are there any Do's and Donts when changing them?
BENS 8
Postby matt dunn » Tue Apr 05, 2005 1:17 am
there are a couple of different types,
as long as you have then right one you should have no problems.
They're pretty simple to do.
Matt
Users browsing this forum: Bing [Bot] and 2 guests
