seatbelts
seatbelts
Postby baker » Mon Apr 04, 2005 10:03 pm
wheres the best/cheapest place (not crusty old seatbelt, but not over priced) place to get a seat belt? my drivers belt keeps locking, some days it can take 5 - 10 minutes to get it out, other days it works fine (luckily it worked for me WOF today!)
also, when I do get one, how easy are they to install, and I mean EASY. im a mess when it comes to installing anything (unless theres someone in st heliers/glendowie area who cud help me out).
assistance would be wicked.
baker
Postby gordon77 » Mon Apr 04, 2005 10:25 pm
im not sure how hard they are to install but being seatbelts you might wanna get a professional to do it, seatbelts are crutial things in you car 8O
there are a few specialists around auckland im pretty sure so yeah, have a search in the yellow pages...
What is RR?
gordon77
Postby Mr Revhead » Mon Apr 04, 2005 11:57 pm
a few places... me, repco, etc etc.
what kind of car is it? if you car has airbags and pretensioners let a pro do it....
Postby Ae92typeX » Tue Apr 05, 2005 12:23 am
generally there easy as to install, 3-5 bolts, possibly one or two wire connections and youre away.
If you cant shift a spanner then not really diy, but in general there easy as.
Ae92typeX
seatbelts
Postby baker » Tue Apr 05, 2005 8:03 pm
nah, im not that retarded. sweet, any idea of cost?
its a ae92, so no airbags, etc. ill look at it first to see if i get a pro to do it or not
baker
Postby Ae92typeX » Tue Apr 05, 2005 8:33 pm
from memory (dont have an ae92 anymore) for the belt you have 3 bolts- 1 holding the main unit, 1 on the roofline, one on the floor/sill. The only one that is harder to get to is the main unit which involves taking off the rear 1/4 internal pannels. to do this you probably should also take out the rear seat (just the lower section).easy as job.
sonce you didnt fail on wof for it, then you could consider looking around pick-a-part for a good belt, they have the ae9x's in all the time.its only about $16 for a belt there, but yea, make sure its mint.
also, when removing yours, make sure it was bolted in level- sometimes if bolted in wrong they can act much like you described.
Ae92typeX
