JZX100 problem
JZX100 problem
Postby KE20 » Fri Apr 15, 2005 11:04 pm
i got a jzx100 and can't get the boot open. the key turns, but nothing happens, the boot pull lever pulls a cable(yyes theres a cable, you can hearit by the key moving stuff), but the boot doesn't open. and the fuel tank is behind the seat. any ideas?
KE20
Postby NA Drifter » Fri Apr 15, 2005 11:46 pm
using key, turn it and maybe lift the boot after u turn the key?? else sit on the boot or apply some force down then try the key at the same time? then get off the boot?? maybe u have got something stuck between the latch.. like a cloth or carpet etc... or maybe the latch bolts are loose.. good luck man...
can u go into the boot from inside the car?
else, break the lock .. if no luck... :twisted: i got a aftermarket key lock thing here that i want to get rid off. :wink:
..Keith..
Keith
NA Drifter
boot
Postby KE20 » Sat Apr 16, 2005 7:47 pm
i tried all that,and brendan and lance both had a go and can't get in.
KE20
Postby Stu- » Sat Apr 16, 2005 10:02 pm
Screw driver and a hammer :D
Else I've got an axe you can borrow....
Project Thread
Stu-
Postby Shotgun » Sun Apr 17, 2005 10:40 pm
A long shot but worth mentioning... Are you using the valet key that only works on the ignition? Can you unlock/lock the glovebox with it? I've got a funny boot lock over-ride thing under the steering column thing, do you?
I was raised by a cup of coffee
Shotgun
Postby Caveman » Sun Apr 17, 2005 11:20 pm
I remember we had a ford fairlane which had a boot override. You bridge a jumper somewhere near the fuse box. Don't know if these jappa's have it though.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby Shotgun » Mon Apr 18, 2005 1:40 am
When I mean boot over-ride, I mean a place where you insert the master (not valet) key and it makes the boot unopenable. That's what I have. Can't say I have my head around it totally...
Shotgun
boot
Postby KE20 » Thu Apr 21, 2005 2:58 pm
the key i have is a copy, but it locks/unlocks glovebox. i removed back seat and parcel tray and when i remove the middle seat belt, i can see into the boot(with a torch) and it looks like it has some sort of electronic thing. i tried using a socket to undo the lock but can't. i was thinking that may be the original key had a boot open/unlock thing built into it
KE20
