Clutch service & Carb Tweeks
Postby 4afeTyro » Wed Apr 20, 2005 1:13 pm
Hi there people - my 98 Corolla GL is n need of a Cluth Service soon. Just wondering what else I can get done in that area whilst its being serviced.
AND can a Carburetor specialist tweek my carbs to improve performance? Dunno how it works I just heard it can be done.
Thanks
4afeTyro - Toyota Convert
Not a Race Engine..Bugger!
4afeTyro
Postby Ae92typeX » Wed Apr 20, 2005 2:23 pm
clutch service?
...you are replacing or?...whats it doing
Ae92typeX
Postby bogjob_kp60 » Wed Apr 20, 2005 4:25 pm
wow, 98 corrolas have carbs !!! :o
bogjob_kp60
Postby 4afeTyro » Wed Apr 20, 2005 5:40 pm
bogjob_kp60 wrote:wow, 98 corrolas have carbs !!! :o
Mybad - got Carbs and Cams (Twin) round the wrong way, and info was wrong, sorry :roll:
Re Clutch - its a whole clutch job!
Clutch appears to be slipping so my garage recommended a clutch replacement which is around 6 hours work and $$$.
Can you recommend another clutch system or shld I just stick with the standard?
Thanks
4afeTyro
Postby Dr-X » Wed Apr 20, 2005 5:56 pm
Replace with a standard OEM replacement.
Are you asking if you can have your cams tweaked? If so, the short answer is no.
Dr-X
Postby Lloyd » Wed Apr 20, 2005 9:34 pm
Not really a lot that needs doing when you replace the clutch. New clutch, release bearing, machined flywheel and thats about it. Fresh trans fluid if you want and a rear main seal you might as well do if its getting on in kms. You probably wouldn't want to have to get gearbox, clutch and flywheel all removed again just for that seal if it starts leaking.
Postby 4afeTyro » Thu Apr 21, 2005 11:16 am
Appreciate your response Guys! Enjoy the long break. Drive2Survive. The best thing in life - is Life itself!
4afeTyro
Postby Rob » Sun Apr 24, 2005 4:42 pm
Your mechanic is pretty toast if he is quoting 6 hours for a clutch in a bloody corolla...Thats almost an engine swap
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby 4afeTyro » Tue Apr 26, 2005 3:45 pm
Rob wrote:Your mechanic is pretty toast if he is quoting 6 hours for a clutch in a bloody corolla...Thats almost an engine swap
Job is about 4.5 to 5 hours and cost around six hundred.
New clutch, release bearing and machine flywheel with Clutch fluid.
1st time paying for a clutch job and not sure if this is a reasonable price.
4afeTyro
Postby Mr Revhead » Tue Apr 26, 2005 4:41 pm
yeah 6 is a bit excessive, more like 3-4
Postby Ae92typeX » Tue Apr 26, 2005 6:24 pm
4afeTyro wrote:Job is about 4.5 to 5 hours and cost around six hundred.
Yea, years ago I was quoted about 6 hundie from toyota for my levin clutch to be done, so that sounds about right. ...I ended up getting done by g'friends dads mate for $200...now I'd only do it myself (but thats going offtopic).
Ae92typeX
Postby Rob » Tue Apr 26, 2005 9:41 pm
Im pretty sure that clutch fluid would come under consumables, and most suppliers of clutches while machine the fly wheel for free. (trade places not repco and other retailers)
Also get your rear main seal done as if it starts leaking after the job is done that will double your cost for replacement.
I would expect upto probably $500 for the job but 6 is over the top
Rob
Postby 4afeTyro » Wed Apr 27, 2005 1:03 pm
Ae92typeX wrote:Yea, years ago I was quoted about 6 hundie from toyota for my levin clutch to be done, so that sounds about right. ...I ended up getting done by g'friends dads mate for $200...now I'd only do it myself (but thats going offtopic).
If I can get the replacement parts, will you have spare time to do a Corolla clutch next month?
4afeTyro
Postby Ae92typeX » Wed Apr 27, 2005 5:25 pm
At the moment im pretty busy with my ethics work for my masters & repairing vehicles on the side for a mate so dont know if I would fit it in sorry bro.
There were afew others on here who did cheep jobs on cars, id imagine you could get the parts from trade parts for about $150ish and perhaps someone would do it for around 1-150ish?
or- get some beers and see if a group would do it!- more hands make faster work...usually...
If you get mega stuck pm me in a month to check on how busy I am.
Mike
Ae92typeX
Users browsing this forum: Bing [Bot] and 19 guests
